Audeze iSINE 10 & iSINE 20: Audeze releases two new IEM planar magnetic earphones
post-15131312
Post #6,781 of 7,155
harpo1
Since this thread wasn't started or maintained by Audeze and it doesn't appear the OP is active in this thread anymore you won't see anything added to the first post. So searching is the only answer to finding info in this thread.
Do a search for KMann EQ settings and you'll find it.
post-15131371
Post #6,782 of 7,155
billbishere
Columbus, Ohio
Columbus, Ohio
Website
www.billbphotography.com
post-15131395
Post #6,784 of 7,155
billbishere
Columbus, Ohio
Columbus, Ohio
Website
Thanks, I found that quite quickly as well. But it doesn't give you the HQ EQ settings for using a cipher V2.
my bad - i am not sure I have even seen that one. Please post of you get.
post-15131405
Post #6,785 of 7,155
cbl117
No worries. The isine10 and cipher cable is quite frustrating because its not very clear what you are starting with when using the Audeze HQ app with flat EQ. I can't figure out if Audeze HQ at a flat EQ already includes the EQ settings found with KMann. The isine10 still sounds a bit off with the cipher V2 and flat EQ on the Audeze HQ app.
post-15131431
Post #6,786 of 7,155
kingdixon
Egypt
Egypt
post-15133553
Post #6,788 of 7,155
billbishere
Columbus, Ohio
Columbus, Ohio
Website
Just saw that. The email is impressive.
post-15133585
Post #6,791 of 7,155
MacedonianHero
Headphone.Guru Editor
Toronto, Canada
Toronto, Canada
I have a review pair that I'll be covering and while I'm at work, I'm using the Cipher Lightning cable with them now on my iPhone XS and boy am I impressed! Just loving what I'm hearing so far...they sound very expansive and dynamic.The new ear-fins work quite well too!
post-15133737
Post #6,793 of 7,155
clerkpalmer
Anyone know of an alternative to the Cipher cable for use with android ?
Anker Cable. Search here. It will convert Cipher to work with your android.
Reactions: trellus
post-15133780
Post #6,794 of 7,155
Mordr3d
India
India
Wow , thanks for the info ! Although I can't seem to find this on amazon or even their own online store , just on amazon US . Are there any other alternatives ? Perhaps one that doesn't involve the cipher cable .
post-15133794
Post #6,795 of 7,155
clerkpalmer
The only other alternative to the cipher itself is to EQ your headphones using the various options discussed in this thread. Honestly, having done both, the cipher is the best plug and play option there is. If you have the time, patience and gear, you can probably improve upon the cipher via EQ options but it really depends on your goals. I had my Android phone using USB Audio app and parametric EQ dialed in pretty well but cipher gets you there quickly. So it really depends.
