lukedss
- Jul 26, 2008
Sorry for the slow response. I just replied to your PM.
Frank
Ordered
Frank
if u use an ios device the settings shared in my post r useless, these settings are when i used it with my android phone, i tried dialing same eq settings on ios and android but the isine did not sound the same.
also a huge thing was for me using double flange spinfit tips to allow deep insertion
Did Audeze come out with a new iSine ear hook?
The ear hooks in the accessory kit on the website look to be the original ones, which are prone to breakage. I keep hoping Audeze will offer more robust ear hook designs as optional accessories.
I finally got my cipher cable to work with the Astell & Kern Sp1000m so I could compare if the cipher cable really is better than standard 3.5mm cable.
The standard 3.5mm cable on a high end DAP is much better than the cipher cable, so to anyone looking to use the cipher cable with their high end DAP I wouldn't bother. A high end DAC like the the A&Ultima is far superior sounding than any sound the cipher cable can put out. And that's with no EQ.
If you have an average smartphone or a low end music player then I'd say the cipher cable is worth it.
From the way some reviews were talking about the difference between standard cable and cipher cable you would think to throw away the standard cable.
Anyway, just my 2pence.
From the way some reviews were talking about the difference between standard cable and cipher cable you would think to throw away the standard cable..
Ive tried multiple EQ settings, and even on balanced, I can’t get the iSine 20 to replicate the depth of music that the Cipher delivers. What settings are you using?
From KMann for UAPP Settings-
To dial in the EQ, please refer to my post: Post #3341
For band 1 also try set Q = 0.7 and move it to Frequency = 100Hz, Gain = -6dB (some prefer this)
- Start with the EQ I posted here
- Since you can only enter 6 bands, in the above EQ (EQ-V1) choose bands 1,2,4,8,9,10 (The band numbers are shown above the values).
- Enter the Gain, Frequency and Q values in Tone booster.
- For filter type, choose 'High shelf' for bands 1 and 10 in EQ-V1 and choose 'Analog bell' for bands 2, 4,8 and 9
How would you enter these settings in a 20 band Astell & Kern EQ?
Es100 is a Bluetooth DAC. Cipher cable is an inline DAC with built in eq for isineim confused after going back and reading this thread, but could someone help me out is the anker usb c adapter for the cipher cable and the use of the es100 dac/amp two totally different things ?
I just purchased the isine 10 with cipher cable/standard
Oh ok so people are using one or the other for eq purposes ?Es100 is a Bluetooth DAC. Cipher cable is an online DAC with built in eq for isine
