Astell & Kern SR15: A&norma Impressions & Reviews
post-15114993
Post #1,876 of 2,434
gordec
Anyone using SR15 with ultra sensitive multidriver iems? I'm looking for a DAP again purely for Westone ES60 similar to W60 and W80. I want to make sure the background is pitch black. I can't stand any noise.
post-15116698
Post #1,877 of 2,434
NovaFlyer
Washington, DC
Washington, DC
I listen to the SR15 using my Empire Ear Phantoms and Campfire Audio Solaris, and I can't detect any background hiss with either IEM.
Reactions: gordec
post-15118033
Post #1,878 of 2,434
ce3eoa
Santiago, Chile
Santiago, Chile
I use it with the W50 and the W80, with both of them it is ok, with the W80 it makes a very good match
Reactions: gordec
post-15118811
Post #1,879 of 2,434
sandy1010
@JasonNYC
Would it be possible to make the slider in artist/song view etc a bit wider? With the case on it can be hard to grab a hold of. Can also be difficult to pull down the quick settings menu with the case on.
also having a small issue where the player gets stuck when adding songs to a playlist. It’ll say “please wait” and the only way to get rid of it is to reboot. On the latest firmware.
thanks.
Reactions: xxAMAROKxx
post-15118878
Post #1,880 of 2,434
Levanter
I have problems with Bluetooth on the SR15.
I can connect my WF-1000XM3 with the SR15 Bluetooth however no sound comes out.
Anyone have similar problems?
post-15118895
Post #1,881 of 2,434
david632
uk
uk
Daft question but have u put the volume up on the headphones
post-15118927
Post #1,882 of 2,434
Levanter
This TWS volume is controlled by the source. It doesn’t have volume controls.
post-15122673
Post #1,884 of 2,434
Starlights
Jakarta
Jakarta
Hello guys,
curently im going to buy a used of this sr15.
Wanna ask ....
how long the battery could last ?
Form the ak spec 11 hours.
And is it worth buying a used one for $483 ?
Thank you
post-15122769
Post #1,885 of 2,434
nicodem
Warsaw, Poland
Warsaw, Poland
sr15 never lasted for 11hours for me. Mine is up to 8h max.
I'm selling currently for almost same price with astell case so I think price is good.
Staying with Kann cube
post-15123283
Post #1,886 of 2,434
Levanter
have you downloaded the sony Headphones Connect app? this may help you
Don’t think you can download that app into AK devices...
post-15123904
Post #1,887 of 2,434
MadDane
Napa Dapa Doo.
Napa Dapa Doo.
post-15127971
Post #1,889 of 2,434
Irvine, CA
Irvine, CA
@JasonNYC Any updates on the Neutron player firmware?
no issues with installing and running the trial version. I purchased a license directly from them since I cannot purchase directly from Google Play store, but to authenticate the license is pretty shady. They want you to enter your email server info and your login info so they can check your inbox for the purchase license message. I don't feel comfortable giving them full access to my email account. I am going to reach out to them and see if there are any other options to authenticate. If anyone who uses it knows and can share if there is a different way to authenticate a license purchased directly from Neutron, I'd appreciate it.
Astell&Kern Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
https://www.facebook.com/astellnkern/ https://twitter.com/astell_kern https://instagram.com/astellnkern https://us.astellnkern.com support.inc@iriver.com
post-15127980
Post #1,890 of 2,434
nekromantik
Yes its very awkward way of validating it.
I hope they give a 3rd option to purchase.
EDIT:
Other way is to create a new email account to purchase license with. And use that for them to check. I would do that.
