Did he really said this ? When/where ?
I thought someone who attended CES said so. I don't really remember who it was though.
But I am pretty sure they'll introduce something nicer than KANN at High End. Let's hope it doesn't follow KANN's looks...
It charges but it just doesn't reach 100%? How far do you get? Are you using the original AK microUSB cable?Hello all. New member here and need advice as could not find it. I have an 1.5 year old ak380 and the battery does not charge to 100%. Any idea what might be the problem. Have used a 5v with 2.4a and the cable is 5v with 1.8a. Is it the component problem, the battery, the charging part needs to be cleaned or something else instead. Your suggestion and help would be appreciated.
I guess you've tried conditioning the battery. If that fails in improving the 92%, then I guess time for a service (battery change).Hi there. Generally it mostly reaches 68% and using original cables. Have charged it for 12 hours and best i get is 92%. Then charge another 3 hours and still the same.
Google that up and you should find some info.How do i condition the battery. Thanks
I don't believe the AK players support LDAC. The Ak380 supports AptX instead.Hi
would like to know if AK380 cu is compatible with the LDAC function of Sony via Bluethouth.
I'm about to order the headphones Sony MDR-1000X, but as they are not APTX-HD, if LDAC is compatible with both, I would order these headphones.
thx
Looks like my AK380CU will no longer be the best of the best of the best...
https://www.head-fi.org/f/threads/new-tol-a-k-dap-the-ak-ultima-sp1000.850061/
