czajunia
- Aug 3, 2013
Is there some sort of a clip case available for the AP80? Similar to Fiio M5 and Shanling M0? If not, has anyone come across a design that could be 3d printed? Cheers.
Thanks man. I guess it could work if wearing a belt of some sort. I noticed ppl use this with an arm band which I am not a huge fan of but the belt might be doable actually.maybe this one
https://www.head-fi.org/threads/ap8...es-music-player.878141/page-217#post-15230997
i duno, i never use a case
I've used the official leather (leather-like?) case on my belt. It comes with an elastic band, but the loop opens and closes with a snap, and fits over a standard man's belt without a problem.Is there some sort of a clip case available for the AP80? Similar to Fiio M5 and Shanling M0? If not, has anyone come across a design that could be 3d printed? Cheers.
If they'd merge the two cards into one database, that would be awesome. Unfortunately, most of the dual-SD devices make the user remember what is where. It's very old skool.they should have put another micro sd card slot in it
even if it was just a dummy slot to hold one extra so you could swap them out when your out and about
Page not found.
Price will go up so it will be competing against Hiby R3 Pro, that's why it should have Bluetooth 5.0 if we are talking about improvements.I see that Hidizs is again advertising the AP-80 PRO... Anyone seen any pre-release reviews for the PRO model? Aside from dual DACs and a 2.5mm Balanced Out, not sure what else is new. Wondering if any sound or battery life improvement.
Anyone got that website saved or something? It doesn't work as of now and someone said they updated it.
Thanks.
Thanks.
OK it looks very pretty but they didn't put any bigger battery in it (800mAh) and battery life looks rather poor, 8-11h and 6-8h balanced? If it's around 199 like R3 Pro most people will pick that one up.
