Sven2015
- Sep 15, 2015
All database items are not cached. The player is limited by the file limitation and there is also the limit of the database.... worst performance
Excuse my ignorance, but what does that mean? Limit of the database and it not being cached and how that affects performance? I’m curious.All database items are not cached. The player is limited by the file limitation and there is also the limit of the database.... worst performance
Thanks for the info!
Just installed v1.2 and (for me) DSD works now! No more hiss.
-> for example a SQL database -> many fields for cover, artist, title and so on....filled with numeric, alpha numeric or other information -> these are entities / records, a bundle of records is a table, many tables are the databaseExcuse my ignorance, but what does that mean? Limit of the database and it not being cached and how that affects performance? I’m curious.
If you create a database you have to create a schema -> which includes, tables, views, indexes and so on
with this schema you create the table space with all information about storage, indexes and so on -> this is important for the database performance!
Without a good table space and indexes you can see a worst database where the database will create all the entries / indexes new when you start the database. And you have this issue for all items / index such artist, title, genre, cover and so on. For AP80 you can see a bad created database.... the databank designer has to re-structure this database....but it seems there is no good database designer @Hidizs
btw. it's not just the cover-caching, all items are affected. For example. You have many albums @genre "techno". When I open the table / view genre, there is no reaction of the AP80 anymore until the database is indexing the files with displaying afterwards. We are talking about of several minutes non-reaction! For a larger file amount you cannot use that database...maybe the reason of the file limit...Hidizs knows about this problem / issue!
So I got the AP80 as a gift. I am wondering I should keep it or return it because of all the issues and get either the FIIO M6 or Hiby R3?
I mostly would use it to listen to ALAC, WAV, and MP3 files on the go. Do not plan to use many of the other features. I just want the best sound for $150. Are the other issues bad enough that it still isnt worth it for this use?
Maybe try changing something in the Play settings like: Play mode, play through folders, play through albums? Maybe try a factory reset?Hi, when I am using teh AP80 in my car with Bluetooth, it stops after each track. Does anybody have the same problem ? I looked everywhere in the car and the AP80's BT options and could not find anything. Any ideas ? Thanks.
Done all that and still no solution.Maybe try changing something in the Play settings like: Play mode, play through folders, play through albums? Maybe try a factory reset?
I don't have that problem in my car.
Good luck
