theMUKe
Does this have any line out capability?
Yes, you can activate line out in quick settings (swipe from bottom).
Is the quality of the line out good?Yes, you can activate line out in quick settings (swipe from bottom).
I’ve noticed that if I let the AP80 set the codec, I’ll get a small tick noise on my car stereo. If I set it manually to sbc, I don’t get the tick. That’s about all I’ve noticed between the two.I recently got a pair of inexpensive "true wireless" earbuds from a company called Haylou. They're very comfortable and small, but are only SBC/AAC capable. While I've used SBC speakers and headphones with the AP80 before (almost daily with an Anker Soundcore), this is the only one that has given the AP80 trouble. I leave the AP80 set to high quality mode, and have it negotiate a codec. With my AptX headphones, it's fine, and with the SBC speaker, it's also fine. When I tried to pair the Haylou buds, they appeared to pair correctly, showing the S indicator for SBC, but as soon as I hit "play" on the AP80, the DAP would reboot. Setting the AP80 to SBC mode fixed it. The AP80 pairs quickly with the buds without a problem.
So, are there other SBC devices that require this manual configuration, or is this especially twiddly?
I'm taking delivery of one of these today. I'll be using it through my car speakers hooked up to my head unit that I had a headphone cable attached to but can also accept USB. So does this output on both the headphone and USB connections? And if so is one inherently better than the other sound quality wise?
Yes, if the headphone has a DAC it can work by USB. And the quality is up to you, if you like the AP80 sound more than the one from your USB headphones.
I know this is a headphone forum but I won't be using them. I want to use the AP80 DAC and output to my head unit. So if I output from the AP80 to my head unit using the headphone jack I'm using the AP80's DAC and if I output via USB I'm using the connected device's DAC....is that correct?
Yes, that is correct!I know this is a headphone forum but I won't be using them. I want to use the AP80 DAC and output to my head unit. So if I output from the AP80 to my head unit using the headphone jack I'm using the AP80's DAC and if I output via USB I'm using the connected device's DAC....is that correct?
Should be better. But why not ask in the M6 thread? There should be more folks with advice there than in the HIDIZS AP80 thread.Hi guys, I’m not an audiophile man but I have one question. I have an LG V20 and I would like to know if it is worth to buy the Fiio M6 as a lg v20 audio replacement?
