acroyear
Backer #528. No communication from my messages to Hidizs.
You will have it don't worry! Like I said, HK is a special case as it is very near for the shipping so they received it very fast in a few days! But for the rest of the world the shipping wouldn't be that fast so you will definitely get a tracking number!
Got my AP80 the other day. A nice little device. Great sound with my LZ-a4, BGVP-DMG and Ibasso IT01.
However the little rascal is not able to find my TRN BL3 iem cable for pairing. This is a bummer. A bug in the software!? or am i doing something wrong. Please some advice!
Also no Aptx support on the AP80 in receiving mode to listen to spotify on my smartphone that has Aptx support (redmi note 5) or pc. Another bummer!
I am also wondering why there is an exclusive option to activate bluetooth hd quality on the AP80. Should it not be always using the highest quality codec possible as a standard!?
Hope these flaws will be looked after in the next firmware update!
You know what chip is used for bluetooth?@CactusPete23, sorry, my bad, I made a mistake last night, as I am not much versed in technical topics, I just double checked with the tech team. . So Bluetooth and LDAC can do both ways, receiving and sending and the APTX can just do sending not receiving.
YES, i am aware of the HQ setting.@kenloveme
It looks like @rhmjmango is aware of the setting/option.
Then comes his question/suggestion: what about the AP80 automatically selecting the highest quality codec instead of the user to have to check the option first?
I suppose that all users want the best available quality as default, leaving the low-res for the worst case?!?!
Is this true? I won't have bi directionaly APT-X?
What the heck?
I think that most of the new players have options for setting the Bluetooth quality, and if we get the LDAC as promised, there will be 3 more choices.@kenloveme
@kenloveme
Hi. From what I saw, embedded covers work for mp3, APE, dsf and FLAC files (I use mp3tag on my PC usually : https://www.mp3tag.de/en/).A question about the cover and how to visualize it in the AP80, should they be included in the MP3 file, Flac, etc? What size should they have or resolution? or they should go in the music folder with What name and extension?.
Thank you
Thanks for answering friendHi
