AP80 - Hidizs next portable Hi-Res music player
Discussion in 'Portable Source Gear' started by IryxBRO, Apr 24, 2018.
112 113 114 115 116 117 118 119 120 121
123 124 125 126 127 128 129 130 131 132
  1. abitdeef
    Ouch! That sucks, I wonder if your red one was one of the defective ones that slipped through. Good luck with the replacement one- I hope they don’t ignore you.
  2. Luhar
    Yeah, just PM'd @kenloveme , hopefully he sees and responds soon!
    Totally sucks, was hoping to break this baby in this month, oh well.
  3. abitdeef
    Hopefully he’ll come out of hiding because you know stuff loose inside a dap can’t be good. Even if it’s the battery, the movement can eventually loosen the contacts.
    Of course let us know.
  4. Luhar
    Yes of course good point
    And I most definitely will keep y'all updated
    abitdeef likes this.
  5. alexzogh
    I don't own an LG phone, but have looked at the measurements and specs. It uses one version higher of the Sabre dac then AP80 with quad burr brown opamps. I wouldn't expect the AP80 to match its sound quality. Be careful making large generalizations about "smartphone's"... There are at least two out there that rival stand-alone DAP's, and this is one of them. May be worthwhile to do some searching on head-fi for the measurements and make a judgment based upon some data.
    Here are some measurements from their previous generation last smartphone:
    https://www.stereophile.com/content/lg-v30-hi-res-smartphone-mqa-measurements
    "Overall, LG's V30 measures well—not only for a smartphone, but for a legitimate hi-rez player.—John Atkinson"
  6. djricekcn
    I don't have mine yet but my friend and a very brief opinion of it (If Ken is looking at this forum, I've sent message to hello@ but have not gotten a reply back yet - basically tracking says i received but I don't have anything)
    Keep in mind, this is all my opinion
    In regards of sound, it's definitely no where near the best and with the type of songs I "mostly" listen to, even the Low-Tier Hi-Res Walkman sounds better. But as for bass heavier songs, which I don't listen to often but still do, they sound better with this.
    I like the overall design of it, but I don't like it's touch sensitivity, it's to dull and I have to push an item a few times in order for it to go.
    I wish there was a way to get to that Volume GUI without touching the knob since it's the easiest way to adjust the volume for me
    For the price, it's definitely well worth it. In my situation: if i was simply on the Go and moving around, I would use this, but if I really wanted to concentrate and enjoy the music, I would use else like my NW-WM1A or the NW-ZX2. Basically, if convenience is the factor and without sacrificing lots of quality, this is highly a go but not for relaxing to your music.
    I also got SEEDs from Amazon (even though I ordered with the KS campaign) for the Unblanced version...The headphones are both good and bad. It's bass heavy / deep so it sounds good with most electronica and pop, but it's not good for ambience.
    Again, Ken, please get back to me regarding Tracking saying it arrived but in reality i haven't received anything
    chaiyuta likes this.
  7. Mfrancisn
    [​IMG]
    Sharing this as a warning to those who received their AP80, be careful with the wheel! After a day of use, the wheel came off from the thread while I was adjusting the volume. I was surprised and disappointed that this is the mechanism/assembly for the wheel that they used. Apparently, they used a tiny bit of glue instead of threadlocker solution(eg. loctite red/blue) to secure the wheel to the thread.
  8. silverfishla
    Ewwwww!
  9. djricekcn
    easy to put back on?
  10. Mfrancisn
    You can still put it back by screwing it again but you won’t be able to lower the vol as turning it counter clockwise would loosen it.
  11. djricekcn
    at least you can get that volume meter on the screen, which i see it as the easiest way to adjust volume. my question is, is there any other way to get to this without touching the knob as I dont' really like spinning / turning knobs for any devices (due to the reason above)
    fyi: i'm not talking abotu that small menu you get when you swipe up from the bottom. That menu is horrible to use, very small. i'm talking about the volume meter where the entire screen is nothing but
  12. Mfrancisn
    Of course, you can still adjust the volume via the UI. I like using the wheel as I don't have to wake the screen every time I want to change the volume, saves battery. Only complaint is how it was constructed/assembled.
  13. Winterheim
    I don't have the internal rattle.
    As for the knob, I expected a tighter click and a more snug fit of the knob itself. It wobbles a lot onhand.
  14. abitdeef
    Hmm I’m wondering if the pre production knob was more sturdy? It’s a little worrying because the knob for most folks is going to get quite a bit of use.
  15. toear
    ... the knob would both the hell out of me... Fingers crossed this is not a common issue and one that is easily resolved for those who do have that problem.
    As for backers... Anyone else out there from Canada?
    I haven't heard a peep. I'm a late backers so would not be surprised if mine too a little longer...
    @kenloveme - any love for Canada yet?
    Thanks!
