NZtechfreak
- Jan 19, 2012
64gb Mate 8 finally tracking now, should be here Monday. Going to be so disappointed if they haven't resolved the USB audio issues I had on the P8Max/Kirin 935 SoC.
What micro usb to micro usb otg cable do you guys recommend from Amazon (US), preferably?
Amazon got schiit Ebay is your best friend, this one has a right angle on both side so it won't stick out that much
http://www.ebay.com/itm/301669713346?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT&rmvSB=true
Is there any general consensus on which Android phone is relatively cheap (used) and supports OTG (for USB audio out). What options would one consider if they wanted to pick up a smartphone dedicated for this purpose and nothing else?
Surely as this threads grown to such size we have an idea what's cheap can be purchased used and works well?
Define cheap? Agree, must be some options. I've not seen confirmation that the Zenfone 2 supports usb audio, that'd be a reasonable candidate if it did. The Xiaomi Note 3 I think has an SD slot, again, if it works a good candidate there. Secondhand the LG G4 can be had at pretty good prices, it works. The Note 4 secondhand also a solid option, but probably getting a bit pricier there.
Depends what you mean by cheap. I would recommend the Galaxy S3 used from say eBay. I use mine as a dedicated source after being upgraded by my carrier. I was going to sell it as I usually do with upgraded handsets but decided jump on this train.
I have rooted it, uninstalled everything except the necessary using titanium backup pro and I am very happy with the performance of it as a source. The only drawback is according to specs is it only supports up to 64Gb MicroSD but not sure if anybody has tested any higher capacity cards. In addition it's not slated for any updates after Android 4.3 AFAIK.
I have tested it with UAPPro, Hiby and Onkyo and they all worked flawlessly though now I only use UAPPro as it supports Tidal. I have never had any issues with it connecting to my oppo or my 4 year old iBasso D6 which was a pleasant surprise.
Edit: Just looked on XDA Forums and it does support 128gb FAT32.
When you say natively you mean within the android framework right and using apps like Poweramp or Neutron for example.
