Android phones and USB DACs
Dec 11, 2015 at 4:07 PM Post #7,576 of 9,526
Hello guys,
I just got an Asus Zenpad running lolipop, I've tried it on three different DACs (Ifi micro IDSD, Schitt Bimby, Teac AI-301DA) using two different OTG cables, symptoms are the same : there's some sound but mostly an annoying continuous, cyclic 'tick tick tick' above it that I can't get rid of...
Anyone experienced this with other devices?
Thanks
Dec 11, 2015 at 10:00 PM Post #7,577 of 9,526
OK I must be super lucky. I had a nexus 6 and now nexus 6p, plugged them into my modi and idac2 and both worked right off the bat with Google music and cloud player. Even seemingly does full 24/192 on my 6p (at least according to my idac2 led)
Dec 12, 2015 at 2:26 AM Post #7,578 of 9,526
@JuleZ3C
If I remembered it correctly (it happened 2 yrs ago).
2 things:
a. It went away when I hook up my DAC to an external power using a Y cable.
b. When I upgraded my Android OS to 4.4.2
Dec 12, 2015 at 8:28 AM Post #7,579 of 9,526
Thanks m-i-c-k-e-y
I'm on Android 5.0.2, and two of the DACs I tried are externally powered...
Dec 12, 2015 at 9:54 AM Post #7,580 of 9,526
Player? I have my best experiences on UAPP next Hiby
Dec 12, 2015 at 9:56 AM Post #7,581 of 9,526
Which micro USB to micro usb cables do you guys recommend?
My Oppo HA-2 sometimes works flawlessly with my HTC One M8,and other times won't work even though the phone is detecting the DAC and going into USB Host Mode.
I'm running Android 5.0.2.
I'm hoping a new cable may solve the issue.
Thanks!
Dec 12, 2015 at 3:07 PM Post #7,582 of 9,526
Thanks!
I made the cable myself. It is just a four wires straight through cable, with pin4 and pin5 shorted at both ends. If you have a DMM, you may check the cable first. But I don't think it's the problem of the cable.
Dec 13, 2015 at 9:04 AM Post #7,583 of 9,526
thanks to someone on xda forums manged to get my E17 working with my Note 3
before I had very distorted - slow sound - very wrong
http://forum.xda-developers.com/showpost.php?p=63562588&postcount=26
thanks to above post/poster
after trying above my USB DAC works with Spotify :)
tried same "trick" with my Tab S - and no go :frowning2: but works fine on my Note 3
Dec 13, 2015 at 7:46 PM Post #7,584 of 9,526
Interesting. Why do you think it works sometimes, but not others via Android? I've swapped out cables, and never have an issue using it with my Windows 7 pc.
Dec 14, 2015 at 3:45 AM Post #7,585 of 9,526
I have a Samsung Galaxy S3 (i9300) as a dedicated music player.
It was on an Android 4.3 based OmegaRom (pretty similar to stock), and was working fine for USB audio out to my FiiO E18 either from Android or via Onkyo/USB APP.
I've started using Tidal and the Android App wasn't working well with 4.3 so I upgraded to Cyanogenmod 11 ROM. I can no longer get Android audio out over USB and can only use Onkyo or USB APP.
Is anyone aware of a ROM that will restore USB audio out from the dedicated Spotify and Tidal apps, or a way of getting this to work on the S3 under CM11?
I can use Tidal via USB APP, but want to have access to offline content for which I need the dedicated app.
TIA
Dec 14, 2015 at 4:32 AM Post #7,586 of 9,526
To make it work, the cell phone and the HA 2 must be physically connect(HW) and communicate (SW).
If your cable is a two way OTG cable and is not broken, the cell phone and the HA 2  is physically connected. Nothing special about it really.
If it can't communicate flawlessly, it is the SW, either the firmware of the cell phone or the HA 2 or the music app itself or some SW conflicts between apps.
Temporary uninstall all the music app, just use the music player of the M8 and see if it works all the time. If it doesn't, it is the M8 firmware issue. If it does, reinstall back Tidal and try it.
Android is completely different, don't expect it work like window. Even my LG G3 works flawlessly with the HA 2, if you are planning to buy the V10, you still have to search the web and see if it works.
The firmware version of my HA2 is 6.76.
Dec 14, 2015 at 11:51 PM Post #7,587 of 9,526
  Man, can't get my JDS Labs ODAC to work with my new 6P. Have tried using this cable and a cheapy type c to type b adapter, no good.
Interestingly UAPP recognises the DAC being disconnected and suggests Linux can see it, but the phone refuses to boot with the DAC connected. So frustrating, used to work fine with my S4 and S5, failed to work with my S6 (someone here reported success with this) and now my 6P.
Has anyone had any luck with the ODAC specifically on the 6P? The DAC still works fine on my PC.
Thanks
How about using a reportedly working USB Type-C to USB Standard-A receptacle adapter?
If the tests are successful, apparently the USB Type-C to USB Mini-B cable is not functional (CC pin of the USB Type-C plug not connected to GND through a resistor Rd (5.1 kΩ)), then fix the USB Type-C cable or buy a new one.
  Thanks DanBa
I'm concerned its not the cable, however I have no reasonable other way to test it given its terminations.
Despite this, I've just now purchased a Type-C to USB Standard-A adapter from the Play Store (to ensure compatibility) in the hope it will work as you have outlined above. If this fails I'm going to run the ODAC over with my car and set fire to my large collection of expensive type C cables.
Will report back
So my Type-C to USB Standard-A adapter from the Play Store has arrived and I've had some time to test.
6P > Type-C to USB Standard-A adapter > regular old type A to Micro type B > ODAC > Amp > monitors.
Still can't get the ODAC to work with the 6P.
It will briefly indicate the ODAC has connected before immediately stating it has subsequently disconnected. The phone refuses to reboot, or boot with the DAC attached. Offers default app USB use when I unplug the ODAC, but will not recognise it after plugging it back in. I've tried all the USB connection options, no luck with any of them. I'm picking this is a power supply issue and not due to the aforementioned cables.
Sadly, I'm giving up with the ODAC for Android use.
Thanks again to those who offered assistance.
Dec 15, 2015 at 11:05 AM Post #7,588 of 9,526
@1235 it should work if every software/hardware USB audio-required component is functional.
Android USB audio
FAQ
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs
I have an Android device, a USB DAC and a USB Type-C cable which are reportedly compatible, but I have not been able to make it work. Is there a trick to make it work?
Nexus 6P is reportedly compatible with a standard USB DAC (i.e. the USB host driver of the Nexus 6P can work with the ODAC).
The Google USB Type-C to USB Standard-A Adapter is reportedly working with a standard USB DAC like the ODAC and a dual-role Android device like the Nexus 6P.
I have an ODAC.
My ODAC is compatible with the following different third-party USB audio soft drivers: UAPP, HibyMusic, Onkyo HF Player, Neutron (i.e. UAPP, HibyMusic, Onkyo HF Player or Neutron running on a Nexus 6P, an Android device with a fully functional USB host driver, can work with an ODAC).
And I just found that the ODAC is no more compatible with the native USB audio of the current version of Android running on my Samsung Galaxy Note3. A few weeks ago, at the upgrade to Android 5.0, it worked!
It is not a problem for me, because I listen to music using the third-party USB audio music player UAPP, the best sound music playback software to my ears.
1st question: What (native USB audio or third-party USB audio) music player did you use?
If the native USB audio does not work then you need to use one of the third-party USB audio music players which include their own USB audio function / soft driver compatible with the ODAC.
Some component of the setup is malfunctioning.
Each component should be separately tested: Go to next test only if the ongoing test is successful. A reset of the Android device is recommended before testing.
2nd question: Did you reset your Android device?
. Test the USB DAC with a PC or a Mac:
PC >> regular USB cable provided by the USB DAC maker >> USB DAC >> amp >> headphones
I suppose you have tested your ODAC with a PC / Mac.
. Test the Android device and a USB Type-C adapter with a simpler USB peripheral like a USB mouse or a USB keyboard:
3rd question: Did you test your Android device and your USB Type-C adapter with a simpler USB peripheral?
Android device >> USB Type-C plug to USB Standard-A receptacle adapter >> USB mouse
. Test the setup using the USB Type-C adapter:
Android device >> USB Type-C plug to USB Standard-A receptacle adapter + regular USB cable >> USB DAC >> amp >> headphones
 If the tests are successful, apparently the USB Type-C cable is not functional (i.e. CC pin of the USB Type-C plug not connected to GND through a resistor Rd (5.1 kΩ)), then fix the USB Type-C cable or buy a new one.
Android device >> USB Type-C plug to USB Micro-B / Mini-B / Standard-B plug cable >> USB DAC >> amp >> headphones
"Important: connect your device BEFORE starting the app, otherwise it will not get detected! When you connected your device before starting the app and it gave you a 'failed to initialize or open the USB device' message or similar."
http://www.extreamsd.com/index.php/2015-07-22-12-01-14/usb-audio-driver
Dec 16, 2015 at 12:18 AM Post #7,589 of 9,526
Android USB audio
FAQ
I have an ODAC.
Hi DanBa, thanks again.
For the benefit of the forum I will address your further questions.
  1. I've tried all of the mentioned TP apps. This is in addition to native app.
  2. I'm running 6.0.1, stock, rooted with a handful of Xposed mods. For the record, yes I have tested at completely stock on 6.0 and 6.0.1.
  3. The ODAC works fine on my PC.
  4. Simple peripherals work fine on the 6P with the Type A to Type C adapter.
  5. I've tested with all combinations of possible orders to plug in cables and start apps.
The ODAC refuses to work with my 6P. I'm sure it would work with a powered USB hub, but at that point portability is somewhat defeated. I see someone else reported success with the C5D, but I think this has an internal battery.
In summary, I've tested this to death. The ODAC does not have my recommendation as an appropriate device to use with either a Galaxy S6 or a Nexus 6P. The ODAC will find good use elsewhere and has so far escaped from being run over (so far). YMMV.
Dec 16, 2015 at 12:44 AM Post #7,590 of 9,526
I got my fiio e17 working with my nexus 4 after installing CM 11, installing this kernel , and using a usb otg y cable. Tested using Hibymusic.
