DanBa
- Nov 12, 2009
Also, I have successfully used the network folder browsing in UAPP to wirelessly play files from a 1TB external hard drive via the Ravpower. (I have it playing right now, basically just as a victory lap after all the trouble I've gone to today to make everything work). Once you've downloaded the MobileFun app and connected to the Ravpower via wifi (see previous posts), plug in USB DAC, open UAPP, and set UAPP to play through the USB DAC. In UAPP, select the "Add Music" button (plus sign and music note), select "Network" from the options on the left, hit the green plus sign beside "Network Shares," and you get the four fields I've listed below. Here are the settings that worked for me:
- Name: [the name you gave your Ravpower wifi network]
- Address (URL): smb://10.10.10.254
- User name: [the user name you set up on Ravpower, which is admin by default, I believe]
- Password: [the wifi password, which can rather confusingly be different than the password you set up to use the device]
This means that if you have albums sorted into folders (as I do), you can now direct UAPP to the folder you want to listen to and it plays the whole folder instead of one song at a time... this is HUGELY useful, and a terrific enhancement!!
Don't know if anyone cares about this, but I found it really great, and it's going to allow me to wirelessly supply multiple devices with access to a 1TB hard drive, so I'm pretty stoked about it .
Thanks!
I didn’t know the RAVPower Filehub can be used as:
http://www.ravpower.com/ravpower-rp-wd02-filehub-6000mah-power-bank.html
. a wireless (DLNA /) Samba-compliant NAS server:
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/5220#post_10808222
music files stored on a (2TB) USB HDD connected to a RAVPower RP-WD02 File hub via its USB port >> Wi-Fi link >> Android device using UAPP >> USB OTG cable >> USB DAC/amp >> headphones
. an external battery:
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/5280#post_10834766
Android device >> USB OTG-Y cable powered by a RAVPower RP-WD02 File hub >> USB DAC/amp >> headphones
