Skylab
Reviewerus Prolificus
My objection is simply to what seems to be the creeping sentiment that Class A is some sort of panacea, which it isn't.
Asked this question a few days ago but didn't get a response. Trying again. What do people think of NAD 3030 derivative amps (newer model being C356BEE for example) + the HE-6?
I'm not sure how to do the ohm calculation myself, but from what I'm reading here it says the C356BEE puts out 80W x 2, into either 4 or 8 ohms. (Interestingly rated the same across either 4 or 8) How many W is that into the H-6? Has anyone had the experience of hearing the HE-6 from either the original 3030 from 1979 or its progeny? Thanks!
Oh dear. Just got my HE-6 and I don't have anything (even remotely) up to the task of driving it.
Are there any USB DAC/amps that can power the HE-6 well? Would like a single solution if possible, no particular budget limitation. Anything like that out there?
Stay updated on Audio-Technica at their sponsor profile on Head-Fi.
I use the mojo/gung with the HE-6, and the results are good. It's better than many speaker amps using the taps from my extensive comparisons.
