I run mine HE-6SE with WHAMMY, a DIY amplifier from diyaudiostore.com
Sounds magnificent.
Sounds magnificent.
What op amp is your whammy?I run mine HE-6SE with WHAMMY, a DIY amplifier from diyaudiostore.com
Sounds magnificent.
I'm running either Muzg Audio for balanced sound, or Staccato Audio for more warmth and tube like qualities. Both strongly recommended.What op amp is your whammy?
Sounds magnificent.
Oh, that's interesting. What bias did you end up using? Love the idea oh using ACA to run them. It probably sounds amazing.The Whammy is a super inexpensive headphone I have one with Burson V6 fitted. I've not tried the HE-SE but do have the HE-6 which the Whammy can't drive sure you can listen with it but the HE-6 just comes alive with more power.
Fwiw build the Pass ACA 6W class A power amp use your Whammy as the pre amp for the ACA my HE-6 sounded really nice powered by the ACA.
I've heard about that with Susvaras, but I can see the appeal for HE-6/SEI found the sweetspot for the HE-6s is a 50W speaker amp pushing 8ohms. That translates roughly into 8W at the 50ohm rating of the headphones. I used a Sugden integrated amp that had exactly those specs and it was phenomenal. Dead silent and brought the HE-6s to life perfectly.
Monoblocks work great! Not stupid at all!On speaker amps, the ones I was happiest with were Bryston 2B (about $400-500 used, can also be found as a B60 integrated), Benchmark AHB2 (I had these as monoblocks because I'm stupid like that), and SPL s800 (my current amp).
I wish there was a way to grab those power JFETs. Any power JFETs really.And the nelson pass F1j is 10 watts per chennel and is the best amp for a long while to drive the he6
In your opinion, I think you forgot to sayAnd the nelson pass F1j is 10 watts per chennel and is the best amp for a long while to drive the he6
