Aug 14, 2012 at 9:36 PM Post #541 of 6,101
I don't. I use a high quality 10 ohm non-inducting resistor in parallel with the HE-6's 50 ohms
to bring down the impedance to about 8 ohms at the amp's 8 ohm terminals.
HiFiman's adapter box also uses a 10 ohm resistor in parallel and a 25 ohm 1/4 watt resistor in series for protection.
Aug 15, 2012 at 5:01 PM Post #542 of 6,101
If the tube amp is OTL or high wattage (>90 wpc), then you want to use the box or come up with your own resistor setup, but if the amp is transformer coupled and modestly powered it's not necessary.
Having said that, I have a 10 ohm resistors in parallel on my modestly-powered SS speaker amp, as equalizing the impedance makes me feel better
Aug 15, 2012 at 10:42 PM Post #543 of 6,101
Got my Copland 504 tube amp today. This amp is very non-fatiguing. Detailed yet non-offensive.
This amp is for pure listening pleasure, vocals in particular, its magic is in the mids.
This is my end of the line amp for my HE-6.
Right now it has 4 EH KT88 reissues. I'll swap them with GE 6550 later.
Aug 16, 2012 at 10:34 PM Post #545 of 6,101
Yes, no SS amp has this mids regardless of price, you only get this with very good tube amps. It beats my audio research d70 hands down.
Also, this amp has upgrades and the previous owner used Raytheon 12au7 instead of 12ax7. As you all know, 12au7 is pin compatible with 12ax7 except it has lower gain.
I need to add this, its relevance with the HE-6.
The HE-6 is like a messenger, don't blame the messenger.
Aug 17, 2012 at 1:02 AM Post #546 of 6,101
If you add a tube pre to a SS amp, it too can have euphoric mids.
Aug 17, 2012 at 1:38 AM Post #547 of 6,101
Which tube pre and which SS amp? I'd like to try it if I can afford it.
At one time I had a tube pre, a VTL Ultimate, and solid state amps, a pair of Krell KMA-160 monos. It was nice powering my Apogee Scintillas ribbon speakers at the time.
Aug 17, 2012 at 2:42 PM Post #548 of 6,101
I use a tube output dac with my ss speaker amps. It used a 12ax7 and I rolled several without much difference. Then someone recommended a GE Command 5 star 12AY7. I like better than any of the 12ax7.
Aug 17, 2012 at 4:50 PM Post #549 of 6,101
The different gain factor is:
12ax7 - 100
  5751 - 70
 12at7 - 60
12ay7 - 45
 12av7 - 41
 12au7 - 19
The following is from the tubestore.
"The gain factor of a tube simply measures how much it amplifies the input signal.  For example, the common 12AX7 type has a gain factor of 100, while a 5751 (which is often used in place of a 12AX7) has a gain factor of 70. This means that if you plug a 5751 into a socket that expects a 12AX7, the pre-amp will have about 30% less gain. Not only will this make the amp quieter, but it can also alter the sound by making the power section work harder when you turn it up. Many guitar amp users (particularly harmonica players) like to reduce the gain to get a different sound or calm the amp down to prevent feedback."
Aug 19, 2012 at 3:01 PM Post #553 of 6,101
12ax7 - 100
  5751 - 70
 12at7 - 60
12ay7 - 45
 12av7 - 41
 12au7 - 19
Quoting my own post.
I think I'm beginning to understand this gain factor but I can be wrong. I was checking the bias of my Copland.
My amp is designed for 12AX7 with 6550s, bias should be set at 45mv. The previous owner swapped the 12AX7 with 12AU7. The 12AU7 has a gain factor of only 19% relative to the 12AX7. When I measured the bias voltage on each tube, they were very high, like 230mv and higher. It didn't make sense to me. When I brought it down to 45mv, the sound became flat and thin. Again, it didn't make sense to me.
Then it hit me. I have to adjust for the gain factor. I should set the bias at 45mv/0.19 = 236.8mv. After I adjusted each one, the magic returned.
Edit: I was told that my setup is not good cause it overdrives the 12AU7. But it sounds good so I'll stick with it for now.
There must be a moral here somewhere.
Aug 19, 2012 at 10:06 PM Post #555 of 6,101
Thanks for the reply. Do we always need to connect through the 8ohm speaker taps or can it be via 4ohms as well? I suppose any decently made Chinese tube amp should do?
If you use the 4ohm tap from the tube amp, you need to parallel a 5 ohm resistor instead of 10 ohm. The resistor must be non-inducting.
