LarsHP
From a technical / power viewpoint 200W @ 8 Ohm is much more than enough, but will it sound the best for the money you spend? That will only a listening test tell you.
A high end class A speaker amplifier rated at 30W may very well sound much better than a cheap run-off-the-mill 200W amplifier. In other words how good it sounds is not as much about the power, but more how transparent / resolving etc. the amplifier is. Many has reported very good results with the First Watt F1J which according to the designer, Nelson Pass, delivers about 1 Watt in 50 Ohm. This translates to about 6.25 Watt in 8 Ohm.
Some amplifiers has an extra emphasis on bass, some sound bright, some are warm sounding etc. etc. and all may measure well and neutral. The sound characteristics should of course match your taste (in combination with the other gear you use).
For the record I just listened to the Anthem Integrated 225 (225W in 8 Ohm) and it did have an extra emphasis on bass. However, I didn't like it half as much as my 50W class A speaker amp. The Anthem is a bit lean sounding in the mids to my ears and it's not nearly as resolving / transparent.
If you do the "Fuzzor" mod (put felt on the inner grill) http://www.head-fi.org/t/692494/hifiman-fuzzor-mod-driver-backwave-felt-damping-modification
and mount Audeze pads with double sided tape, you will get the bass you want. No need for a high powered speaker amp. A speaker amp might sound the best, but not because of the super excess power (like 200W) it has.
These are my experiences with the gear that I have heard.
