khaine1711
- Dec 12, 2011
25Ohm parallel -> The amp will see 16.666666666 Ohm load.
Generally I try to match the load with the tap - just because I can! (I also like to spend hours biasing tube within 1mV of each other)
In real world though, any slight change around the 25 Ohm mark is fine.
Okay, just read/re-read your post... will do! I'll save money and get a pair of 25-26 Ohm resistors. What impedance will the amp see at this value? Thanks, if I have not said so to all of you.
