preproman
- Mar 16, 2011
http://www.ankaudiokits.com/he6headamp.html
^^^ What brand is that?
The adapter uses ceramic resistors iirc. Just tie a 10 ohm resistor of your choice between the binding post, no need for fancy adapter.
I think wuwhere solution is fantastic too, tuck the legs of the resistor inside the spades/bananas
Help!
Lovely... though, I could use a bit of guidance from here. Just two pieces? I'm use to hearing adapters having four pieces - 1 pair parallel, the other pair in series at a different value. The Shindo's are 16 Ohms, the vintage irons are both 8 Ohms.
That said, the above will work for me? Further, what value (resistance) will each amp see with the resistors? 8 Ohms?
Help!
The resistors in series are not for the amp but attenuate the signal to the headphones. They can help for example if there is some noise from the amp but you do not need them. I have an adapter where I can engage or bypass them, -- I think using then moves you s little further away from the music but sometimes it sounds a bit more coherent. Still trying to figure it out. One potential advantage can be comfort -- I can run speaker cables to the adapter and get 8 feet or so further away from the amp and close to the couch. But it clearly adds expense compared to wrapping resistors to the speaker terminal.
Yes, a resistor in series is a voltage divider too but in the HiFiMan box its only purpose is for overcurrent.
Favorite method of hobbyists everywhere.The resistors in series are not for the amp but attenuate the signal to the headphones. They can help for example if there is some noise from the amp but you do not need them. I have an adapter where I can engage or bypass them, -- I think using then moves you s little further away from the music but sometimes it sounds a bit more coherent. Still trying to figure it out. One potential advantage can be comfort -- I can run speaker cables to the adapter and get 8 feet or so further away from the amp and close to the couch. But it clearly adds expense compared to wrapping resistors to the speaker terminal.
Yes, the 2 pieces we used = only the parallel. Generally you won't need the serial resistor unless you absolutely have no volume control (i.e. deafening volume at 7-8 o'clock). Serial resistors usually affect dynamics so I choose to use none.
In my case, 8 ohm tap, 10 ohm resistor -> the amp will see 8.333333333333333333 ohm.
The Sansui and Pioneer won't require any resistors to operate safely. The Shindo will need the parallel resistors to protect its trannies. If you want the Shindo to see ~16 ohm on the 16 ohm tap, you'll need to use 25-26 ohm parallel resistors.
Silent one, that power box is rarely needed. Transformer coupled tube amps and wanting to use an amp so large that you have no volume control and need to eat some wattage. I use a 125w amp and have plenty of volume control(through digital volume control on DAC and before on a passive volume control between my old DAC and amp). If you are buying new, save the money. You can wrap a load resistor on the posts if you think you can't control the volume knob with security. Takes no tools.
Congrats on your decision and welcome to the club. I think you'll hear what we've heard and lose any interest in other headphones.
