ptrok
- Jan 3, 2011
Quote:Quote:Are they not essentially the same with the concerto having 64 steps of volume instead of 32 (vs the symphony) and other minor upgrades and the stagedac has an additional WM8741 and probably other minor upgrades. So if space and fancier casing is not a concern it should be obvious which should be slightly better than the other. I don't really think that either is the best for the job but if that is what your heart is set on it shouldn't be a bad pairing but I don't know for sure.
In any event I think that is in fact the purpose of this thread... well half of it anyhow accursed stage dac ;P.
Thanks bebop, I'm not set on the concerto or symphony but they are the only amps I know of that may do a good job of driving these cans and are within my budget. If you have a better suggestion within the 1.5k budget it would be greatly appreciated. I want an amp and dac for this price so it kind of limits me with my current knowledge of hi-fi. Thanks in advance.
If I can put my two cents in, some of it depends on what you're going to feed it and a lot of it is going to be how you hear stuff. Honestly, if budget was a huge concern I would actually be able to live with my Forte soundcard's built-in amp or my D10 as an amp/DAC, but taste and aesthetics can vary wildly between different people. That and the different combinations can get a little wacky...like I know I didn't like a certain Marantz CD player feeding a Luxman P1u, but I have no idea if switching one of those components out would make me like it. My main critical areas tend to be mids, followed by rounder trebles with low sibilance, separation, staging, bass, etc....so some of the rigs I really like don't float the boat for other folks.
1.5k should be able to give you a little bit of options, especially if you want to consider DIY/custom-built and out-of-production/used stuff. DACs, in particular, seem to change over relatively quickly, so the 1k DAC of today is probably going to sell for much less in a few years.
thanks for the advice, I will definitely look into those suggestions however do you have any advice for what dac's are worth looking into? The sea of head-fi is vast so without a little direction it can be overwhelming.
