DeadEars
- Aug 13, 2009
Is there anyone using MapleTree Ear+ HD to fit with LCD-2?
How do you think about this amp?
That would be me. If you like intimate recordings (girl with piano, jazz quartets, chamber music) then it works pretty well. Forget it for rock or big orchestral recordings, or EDM or grunge. I use mine at work and listen at low level, so it is nearly perfect for my needs. I did end up modding my EAR to pump up the juice a bit and get rid of the electrolytics in the output path. I'm very happy with the results.
As others have said, the MAD amps are an ideal match with many Grado's. When I want to rock out, those are the cans I reach for.
Best of luck in your search!
