I know this, but nonetheless I was wondering if people had included it in the chain at some point. The other day while waiting for my 10SE to ship I was thinking of a TOTL purely Audio Gd brand setup, so I thought I would ask for the experience of others out of curiosity.
Why not the Master 6 as it puts out more power? The master 6 and Ref7.1 is definately my dream setup.... but i doubt ill be able to afford that anytime soon
i think ill be happy with the NFB-10SE for a while, as im really liking it so far
When you get your fuse I would like to get your opinion on what your thoughts are about the upgrade.I know in my system every component has a hifi tuning fuse in it and i found in my experience so far that the improvement in the equipment performance was defintely worth the effort.When you get your fuse or fuses drop me a reply.
But what do you need the extra power for? certainly not lcd-2s. Besides more power doesnt mean better, and it could make it too powerful to be useful to sensitive headphones.
Hmm, i am a bit confused by audio-gd's page for the master5/6
If you refer to the picture below from their site, the Master-5 is on the left and the Master-6 is on the right. Based on the chart layout it appears that the 5 has alot less power than the 6 (1700mw vs 9000mw @ 50ohm) but i do not think that is the proper way to intemperate it. I think that both amps run in class A until they hit 1700mw and then it switched to discrete power? Therefore the only difference between the 5 and the 6 is that the 6 has more gain applied in both high and low mode? i would appreciate others opinions.
Wasn't the Lyr designed for that? I'm pretty sure that most people don't have the Lyr set at max volume when they use the HE-6s with it, and the Master 6 has 1.5x the power.
I will have to, as I've never heard the HE-6's. I've always wanted to, but they're too expensive on their own, disregarding amp requirements.
On an unrelated note, I'm going to be receiving my NFB-10SE tomorrow, and will post initial impressions with my Nuforce as a basis of comparison. King-Wa managed to get it to me in three or four days, from Hong Kong to Wisconsin.
I received my NFB-10SE, and have been listening to it for the past 20 minutes or so. Initial impressions are that this is a noticeable and worthwhile improvement over my Nuforce. If I still had the option of comparing it to the Lyr/Bifrost I could tell you if it had perfect synergy or not, but so far I am extremely pleased with it. The NFB is phenomenal across the board, at least with the third filter setting. More impressions will come soon as I do more serious A/B testing.
