Sorry didn't read through this thread. Can anyone compare the HDP vs Lyr with LCD-2?
Much appreciated.
Much appreciated.
Much appreciated.
HDP...not ideal IMO...the LCD-2s sounded "polite" and thin with poor dynamics....the Lyr (as Kevin put it), kicks like a mule.
Orthos need power to reach their full potential and 4 W into 50 ohms from the Lyr does a phenomenal job driving both the LCD-2s and even HE-6s. The Nuforce on the other hand is only 250mW ish into 50 ohms...not enough to get your foot in the door with either can IMO.
IMHO, the HDP is overpriced. It's ok as an entry level DAC that happens to have a low powered headphone monitor circuit in it, but it's priced too high for what it delivers.
"Kicks like a mule" is a very apt description of the Lyr. I suspect the Lyr isn't as praised as it deserves because many have formulated opinions based on stock configuration. It's elevated to another level with the right tubes.
Exactly. The JJ tubes are average at best...a bit dry IMO. But roll in some better tubes and you're off to the races. I think many "non tube" fans bought it initially and didn't experiment with different tubes. Thanks to MrScary for rectifying that one.
The Lyr is a better amp at powering my LCD-2s (and HE-6s for that matter) than the more expensive Concerto and WA2. Don't let the price fool you, this is one heck of an ortho amp.
but is it that much better than a HA-160D?
While I generally agree with Kevin based on my experiences, I will concede that the HDP does a "nice" job with the LCD-2s. The thing is, the Lyr with the proper tubes does a fantastic job with the LCD-2s.
With the LCD-2s, I prefer it to the HA-160 and Concerto by a reasonable margin.
I'm currently using HD650s, but considering LCD-2s.
I have an old gadget called a 'Can Opener' from a couple of decades ago, which was designed to connect the speaker outputs of my equally old Naim power amp to a headphone socket.
The NAP-250 that I have will deliver around 10A/70VA continuously, and 15A/400VA peak... but the Can Opener fortunately attenuates the signal to sensible levels for headphones. I used to a pair of old Beyers (1980s vintage 990s?) and it worked fine with them.
I suspect that this might sound spectacular into the 650s or LCD-2s, and it will cost me nothing to try with the 650s. I just need to retrieve it from my friend who I loaned it to some years ago; he's happy to return it.
I'm really tempted by the idea, so do you think I should I give it a try, given how much I like the 650s and the prospect of the LCD-2s?
By all means, give it a try!
