DeadEars
- Aug 13, 2009
Hey Austin,
With your budget, you've pretty well exhausted it after buying the LCD-2's! Or is that your amp budget?
I'm a big believer in DIY as a learning experience. The only issue with building tube amps is you really need to be careful, since most tube equipment operates on lethal voltages. As in: "kill you dead."
Thiings like Pete Millet's "starving student" amp (http://www.pmillett.com/starving.htm) are a nice place to start to learn about electronics, and to make something that will really sound good. Or go to the Bottlehead forum and tune in on some of the great kits there (http://www.bottlehead.com/store.php?crn=224).
Some of the great old Dynakit amps are available in reproduction form, or if you want to save a lot of money, you can buy a vintage version and rebuild it (see http://www.curcioaudio.com/dynadr_3.htm). If you did that, my recommendation would be a Dynaco integrated amp, the SCA-35. Turns out it has just the right amount of power to drive the LCD's really well. The original Dynaco manual even has instructions for how to hook it up. The only downside is that It's not a very modern circuit, but it can be made to sound really really good. And it would be "old school" which would probably please your dad! By the way, Klipsch Cornwalls with McIntosh MC225 amps really do sound very good, although the best I've ever heard MC225's sound is with vintage Quad electrostatic speakers.
I have a Dynaco SCA-35 somewhere in the stack on my TBD shelf, awaiting time to work on it. I think I paid $15 for it at a yard sale. I'm looking forward to hearing my LCD-2's driven by it. As I write this, I'm listening to Buffalo Tom metal on my LCD-2's driven by a vintage 1959 Eico HF-81, most of which started life as kits. Mine cost me $35 to buy, plus maybe $150 or so in parts (not including vintage tubes). A lot of the late 50's through early 70's amps make really fine headphone amps, with claimed outputs in the 15-35 watt range (usually optimistic). With judicious use of modern parts, and a little upgrading -- especially in the power supply -- many of these amps will go toe-to-toe with today's dedicated headphone amps. And you can learn a huge amount by restoring one, plus there are a lot of resources on line to help you -- especially for Dynaco!
Hope this helps!
Frank
Hope this helps!
Frank
