slwiser
- Jun 23, 2001
Long thread for a quick fix...but it should not have been required in the first place.
Originally Posted by sjones /img/forum/go_quote.gif This is my first Grado and my last one as well. While the SR60s are not as expensive as the others in the lineup, I expected much better quality from these. |
Originally Posted by Happy Camper /img/forum/go_quote.gif Unfortunate, but my ebay purchased RS-1s look like this. They have been around with a 1573 serial number but I've had them for three days Bad design. |
Originally Posted by razer /img/forum/go_quote.gif So we pay like 600 bucks or so for some RS-1's and they're like.....cheap leather headband, squarish metal rods and earcups that swivel and swivel till the cheap looking cables get all tangled up..... And then we have the letters R and L painted cheaply on some plastics at the ends. Cheese cloth that covers the drivers....And some wooden housing....Next to zero soundstage....I don't know why but its not supposed to sound that way....And finally, the beautiful carton box that it came in....600 quids for a DIY project I guess? Nevermind if it sounds well but I don't think $600 went all in to fund that research in producing a sound like that right? And boy, these cans are like ear tuned? Or something like that? Hmmmm.....I'll rather keep my $600 I guess....Guess it was my mistake to get the GS-1000's and HF-1's..... |
Originally Posted by SuperNothing /img/forum/go_quote.gif The driver of my HF-1 came out of the plastic housing which was annoying but I emailed Grado, they got back to me the same day and said if I drove them over to the factory they would repair them free of cost. Whatever you say about their build quality, I don't think it is terrible, they have great customer service. |
Originally Posted by Happy Camper /img/forum/go_quote.gif So epoxy or gorilla glue does the job? Only want to try this one time so as not to ruin any future attempt for repair. |
Originally Posted by Uncle Erik /img/forum/go_quote.gif I used epoxy on my RS-1 and it has held up fine. Be careful to clean the tip and the little hole before you glue it. I rubbed the post with some 0000 steel wool and used a slip of 400 sandpaper on a toothpick in the hole. That removes any debris and roughens the surface to help the epoxy hold better. Then I cleaned both with a little mineral spirits and denatured alcohol. You could use Windex or another solvent, as well. I let dry for a few hours then put a little epoxy in the hole and on the tip. I stuck them back together, cleaned off the excess and let dry for 24 hours. So far, so good. Too bad this happens. |
Originally Posted by Uncle Erik /img/forum/go_quote.gif I really love Grados (their cartridges, too) and wish they'd make a few changes to keep this from happening. It's a weak design, but doesn't have to be. There are simple ways to redesign this flaw out. Personally, I think they should just bite the bullet and do it. Warranty claims do have a cost to them and the design hurts their reputation. They should change it. You know, it would not be that difficult to make a modification kit to retrofit all Grados. Hmmm... wonder if something could be cooked up and turned into an aftermarket mod. |
Originally Posted by feifan /img/forum/go_quote.gif Has anyone tried the glue fix on the 1000? |
