Hi,
Here are my comments on the K3003 vs the AK T8ie mkii (the Astell and kern version of the Xelento) https://head-fi.org/threads/akg-k3003-high-end-3-way-system-headphone.554628/page-251#post-13241158. My view is that if you are looking at single dynamic drivers the pinnacle is either the Xelento/T8ie mk ii or the Dita's in their various manifestations. The IE800 was okay but I'd put it a rank below those two. For me the key was fit, here the Xelento is supreme. For what its worth I do not rate the much-lauded Campfire Vega finding it way to bass focused. The lower range Lyra is a more even handed iem but has its own problems (wind noise and the equalization vent). Please note this is with my ears, my sources and my music, YMMV.
For a brief comparo of the K3003 and the Andromeda this comment was made last year https://head-fi.org/threads/campfir...romeda-and-nova.805107/page-168#post-12758865. I found the Andromeda quite pleasant, but found that the housing was too large for ears (same with JH stuff and the 64 Audio gear). As I indicated to James in my earlier response, after the K3003 I found myself gravitating to a DD sound rather than a BA or a hybrid. The sound differences in driver technology should be considered. For what its worth, i did not find enough difference in the CA Dorado, their DD/2BA, over the K3003 to warrant a purchase. Happy to discuss.
regards,
Giles
Thanks a lot!
So you reckon that Dorado and K3003 have similar sound signature and technical ability...?
What BA/hybrid UIEM will you consider an upgrade to K3003 BTW?
