2359glenn | studio
Jun 15, 2016 at 3:51 PM Post #13,516 of 39,998
Glenn
What is the advantage of using four-6AS7's compared to two-6AS7's? More current? In my listening session comparing quad vs two Chatham 6AS7's on my OTL amp, the quad provides more impact/slam on my PM-2. I have never really liked any power tubes combo on my Darna using my PM-2 except this one (quad 6AS7) which is very enjoyable IMO.
Jun 15, 2016 at 4:36 PM Post #13,517 of 39,998
  Glenn
Four 6AS7s instead of two lowers the impedance supply's more current to the phones.
You can also try two 6336B tubes to do the same thing.
Jun 15, 2016 at 4:41 PM Post #13,518 of 39,998
Yes I will be starting the EL3N amp have the transformers now.
Not sure when I will be finished maybe after I come back from Greece.
Probably will be finished before I leave so I would say a couple of weeks.
Enjoy your trip Glenn, and give our best regards to Stavros.  He doesn't come here anymore, but we still think about him.
If you want me to ear test this EL3N I'm ready and waiting.  :)  We'll see if it's reputation for sounding like a 45 is exaggeration or not.
Tyrell I will tell Stavros you said Hi
The amp will be after I come back from Greece I want to play with it for a little while before I ship it to you.
Jun 16, 2016 at 1:49 AM Post #13,519 of 39,998
Well the bad luck train came around to my stop again.
While in the middle of a listening session just now I heard a brief little "buzzzzz" then the music cut out.  I looked over at the amp and saw both current meters had dropped to zero and the plates on both rectifiers were glowing bright cherry red.  It wasn't a loud pop or anything, just a brief electrical buzz then nothing.  It was on and working normally for about 2 hours at this point.
I'm not going to try turning back on or doing anything with it tonight.  I'll check tomorrow after work and see if the fuse is blown.
Any thoughts on what could be going on Glenn?  Thanks.
Jun 16, 2016 at 1:59 AM Post #13,520 of 39,998
Is your amp 300b like Tony's? It seems the problems reported lately are related to 300b amps only. Coincidence?
Jun 16, 2016 at 2:45 AM Post #13,521 of 39,998
My issues were a mix of bad tubes and damage in transit, as best I can tell. The amp itself, after the repair, has been rock solid. Even the failed PY500 that took out my house circuit breaker and blew my DAC USB feed did not affect the amp.
Jun 16, 2016 at 2:59 AM Post #13,522 of 39,998
Nice to know Tony. Cheers.
Jun 16, 2016 at 3:03 AM Post #13,523 of 39,998
No drama. I don't want folks to think that the 300B amp is fragile. Mine has had a blown a 300B and a PY500 since the repair. Only damage to the amp has been a blown fuse (a good thing).
If only my DAC had been as robust
I do recommend swapping out the fuses, as per an earlier discussion, to provide some extra protection for the amp.
Jun 16, 2016 at 4:45 AM Post #13,524 of 39,998
First I would change the rectifiers then see what happens.
It was not a output tube if the meters were on 0.
Could be also be a shorted filter capacitor but I doubt it use hi quality caps.
Most likely bad rectifier I will make you those SS rectifiers as soon as the tube bases get here.
Jun 16, 2016 at 10:40 AM Post #13,525 of 39,998
Okay, I'll put a different set of rectifiers in and assume these are bad.  Why would both of them get red hot at the same time though?  Something to do with how a full wave bridge works?
The power transformer felt a lot warmer than usual too when I put my hand to it.
I checked the fuse and it was not blown if that info helps.
Jun 16, 2016 at 10:56 AM Post #13,526 of 39,998
I hope this will be an interesting respite from the problems some folks are having....
Received a pair of Telefunken C3g today and I am quite sure that these were actually manufactured by Telefunken. Upon close inspection, they do not look like rebranded Siemens to my eyes. What initially caught my eye was the Telefunken date code, "wr" (September, 1966).
Telefunken tubes link
I feel quite certain that as a general rule Telefunken did not put their date code on tubes procured elsewhere and relabeled. So my advice is look for this date code. If there is no date code, they are not most likely not genuine Telefunken.
So in terms of construction differences, how do they compare to the Siemens? First, while the cans are not flat-black and embossed like 1960's Siemens and Lorenz, they are not as shiny as the 1970's Siemens.
Compared to 1970's Siemens
Compared to 1960's Siemens
Since these tubes are enclosed in metal cans, the best and only place we can look for construction differences is the base. Note especially the area surrounding the base of the guide pin. The 1970's Siemens have a prominent escutcheon at the base, while the 1960's Siemens have no escutcheon. That area is almost perfectly flat with only a faint circle surrounding the guide pin. On the other hand, the 1960's Telefunkens have what looks like rays emanating out from the base of the guide pin.
Further, upon close inspection, there are also noticeable differences at the outer edges of the base where the metal cans are attached to the base.
1970's Siemens with prominent escutcheon
1960's Siemens with only a faint circle surrounding the guide pin
1960's Telefunken with emanating rays
Hope this is interesting and useful to those who roll C3g.
Cheers
Jun 16, 2016 at 11:09 AM Post #13,527 of 39,998
How does the telefunken C3g sound vs the Siemens?
Jun 16, 2016 at 11:14 AM Post #13,528 of 39,998
I have only about an hour on them, just enough to verify that they are not defective. And further, they need to be thoroughly burned in before coming to any conclusions regarding their sound. So after they have settled in and I have some time, I will try to compare them. Until then... :)
Jun 16, 2016 at 11:33 AM Post #13,529 of 39,998
Jun 16, 2016 at 11:54 AM Post #13,530 of 39,998
Please let us know.  I got Lorenz and Siemens, but stayed away from Telefunken because they are supposedly the same.
