g0ldl10n
Do you have another amp you can run them in without adapters? I also purchased a quad from that seller 3 or 4 months back and all 4 tubes tested as advertised, and ive ran them with no problems in my amps. If you have another circuit you can try them in without adapters and they still seem to cause issues, id contact seller for replacements, otherwise, we know the issue is isolated to either the adapter or amp, but likely adapter if the amp runs without issue using other tubes.I’m using two, just like I do with the 6J5’s.
