gibosi
- Oct 18, 2012
@RestoredSparda have you cleaned the pins on the noisy tubes?
@RestoredSparda Yes! I use 220 grit sandpaper. Works great!
This is probs a dumb question, but are you allowed to have that front spot empty @RestoredSparda? In mine, the back row can be empty but not the front.
Hoping to place an order for a Glenn OTL - how can I reach out to Glenn?
How about 6AS7?Two is the limit. And this is true regardless of what rectifier you use. The limit is heater current. Two 6336 (or 6528) require 10 Amps of heater current. Four 6336 would require 20 amps. The vacuum tube heater transformer simply cannot provide this much current.
That said, four 6080 require only 10 amps so enjoy!![]()
How about 6AS7?
Thank you, you’ve been really helpful! I got some Chatham Tubgsol 6336 are these considered good or are there better options?Yes, four 6AS7 require only 10 amps and would be safe and fine.![]()
That didn't take long. Congrats on the quick sell.I just posted my GOTL in case anyone is interested:
https://www.head-fi.org/classifieds/glenn-otl.76142/
