UntilThen
- Jun 16, 2015
None of the single pentode tube adapters for Feliks amps will work.
This will work
https://www.ebay.com/itm/1pc-Gold-D...623692?hash=item2cb7a5490c:g:aC4AAOSwJ7RYW8eI
You can also use this on the outputs if you stagger them. Don't know how it will sound the impedance of these tubes might be to high.
Maybe with high impedance phones? But you will need 4 of these tubes and 2 adapters just to try.
I think I will try this since I have all the tubes sitting here. I will need 1 dual adapter for the driver and 2 dual adapters for the powers.
I am not sure whether to run EL12 or EL12spez. If the latter than I need the adapters with the cable for the top anode.
