mordy
- Aug 8, 2010
Sometimes the noise and hum is due to corrosion on the pins so I suggest that you clean them. I use fine sandpaper.
And sometimes the noise and hum is due to sitting unused for 60 years or so. If so, they might quiet down after burning in for several hours.
Except for cleaning he pins and letting the tube burn in I have not yet found a cure for persistent loud crackling and popping after giving the tube time to burn in. However, I have found that using inexpensive high temperature self sealing silicone tape around a tube can cut down or even eliminate hum.
