2359glenn
Member of the Trade
- Aug 16, 2010
Communicated with xulingmrs through pictures .... I think she gets what I want. China is on holidays now so it won't be until 10th Oct before they can start producing that for me.
The EL12 and EL12 spez adapters will be at 45 degrees angle but can be rotated slightly by loosening the centre screw. EL11 and EL12 use the same adapters.
Then @felix3650 it will be nuclear meltdown.
S0 you are going to use 8 of them for outputs. Maybe will work with 8 will get there internal impedance down. These tubes were meant to run at over 400 volts.
Not so high in your amp.
How did they sound in FA amps? Different circuit there just a cathode follower with no gain most anything will work to some degree.
Let us know how the sound is.
