UntilThen
- Jun 16, 2015
Now you may use a pair of 6as7g and a pair of 6080 for a more full on sound.
the 6g13c is perfect dead silent, the imbalance was present but sounds great when i just reversed the tubes and it sounds awesome now I might just leave these in for a while to test etc.Generally keep the pairs to same brands and physical constructions. The latter is more important because rebranding is quite common.
well besides the annoying hum on the left channel atm.... it sounds good
I don't own 6080 any recommendations ? but I do have a pair of 6as7g but they hum annoyinglyNow you may use a pair of 6as7g and a pair of 6080 for a more full on sound.
i didn't but it was only apparent with the 6as7gs tubes and it's dead silent with the 6h13c i'll test it laterOk this is not good. You have to troubleshoot to find out what's causing the left channel hum. Make sure the RCA connector is pushed in fully behind GOTL. Swap the same pair of power tubes around and see if the hum switches to the right?
Hi Glenn,
I have adapters for both the EL11/12 to 6SN7 and EL3N to 6SN7, as well as a dual adapter for two octal tubes into one (6SN7 pinout). However, the EL11/EL3N adapters are made for the Feliks amps, and I am not sure if two of them on a dual adapter would work in the GOTL.
Will it work?
Hi Glenn,
Will it work?
i know this might be a silly question to ask, but having any driver tube, 6x 6BX7GT power tubes my left channel is lacking bass compared to the right channel, I attempted many tests, switched the cable from right to left connected to my headphones, switched drivers used different headphones, tried both SE and XLR and i come to the same conclusion it must be something with the power tubes, I just wish I could find some reliable consistent power tubes so my conclusion is obviously the power tubes are causing an imbalance or lack of bass from my left channel ?!?! well any feedback will be greatly appreciated thanks
You are also one of the first to send your E-amp all the way back for service. LOLI was the pioneer to use 6 x EL3Ns in Elise so I know very well how that sound. I'm also very familiar with how GOTL sound with ECC35 and 6 x 6bx7gt.
I will take the GOTL setup with those tubes, any time, any day, any song over the 6 x EL3Ns in Elise.
Good point. However, many sellers sell used tubes as "NOS"/"NIB".When buying 6BX7/6BL7s usually have to be bought as singles. You have to make sure they are NOS not used!!!!
In TVs 1/2 of the tube was used as the vertical oscillator and the other 1/2 the vertical output. that is why only one side is cooked.
True NOS is more important then matched tubes. Usually you can find six single GE 6BX7s that are NOS.
