2359glenn
Member of the Trade
- Aug 16, 2010
Hello Glenn...
Spoke to the seller, he said it worked after replacing a couple of tubes, and restringing it, so he was happy and didn't do anything else. So yes, I would appreciate a list of caps that are routinely wise to replace.
Yes, fed an MP3 player to the phono input. worked ok. Pretty good amount of HUM is apparent, but it has that audio character typical for the .time..where the low mids are emphasized.
Appreciate!!
First thing is change the filter capacitor and get rid of that hum. It is a 15-15-10 a 20-20-20 @ 450 volts would be fine.
Problem is getting the can out and the new one being the same size. Easier to jump singles in 20uf 450 volt.
Can you solder??
