Ivabign
- Jan 16, 2012
Its been seven months and I still love my V3s like the day, I received them. Eventhough, its sharing head time with SE846. Best $449 ever spent.
Question for people with lighter colour transaparent shells:
Are you seeing discolouration from ear wax?
Mine is turning yellow on the inside of tips.
I clean mine after every use - I have a few transparent CIEMs and as long as I am fastidious, there is no residue left after usage to discolor the nozzles.
Good for you! I too am very happy with the V6S. Tell me more about the cable. I was impressed with your experience and didn't think the difference would be so substantial, now I want one. Which model did you get and is it supple like the stock cable i.e. just falls out straight after being coiled up? Do the connectors fit properly?
Thank you!
The silver cable is a Ted's Headphone lounge 25.5awg braided cable with a simple RSA plug. It rolls nicely and is soft to the touch. The Litz models are a bit thicker, but those are also very ergonomic I have 4 Litz cables from Ted - two copper (2pin & MMCX) and two silver (2pin & MMCX) - the connectors all fit very well - the 2pin ones seat firmly and slip into the CIEMs I have with recessed sockets as well as flush sockets - much better than stock.
