- Aug 3, 2007
You're right, you made me look and now I regret it cause my wallet has had enough of meI shouldn’t have went on ZMFs website…. That zebrawoood Caldera is so pretty. @_@
Question: How about I buy a Schiit Midgard and use with Mojo 2 as only DAC for my Caldera? Would it be a discernible improvement?
Hi @Lyssky. I agree with @theveterans. I am a Mojo 2 user.Noticeably better than Mojo 2 alone
Oh thanks a lot for the response.Hi @Lyssky. I agree with @theveterans. I am a Mojo 2 user.
With an amp the Mojo 2 sees a high impedance thereby reducing current demands on the device. I think this improves the resolution of the Mojo 2. Also most high powered amps will drive the Caldera better than the Mojo 2.
Caveat: I’m noticing amp pairings make a big difference in my listening experiences. I do not like Toppings or the measurement focused Schitt amps with Caldera and Mojo. I preferred Mojo alone in those circumstances. I very much enjoy the Caldera Nitsch Pietus Maximus and my old Vali 2 with a Reflector 6H23pi-EB tube. I’d be lying if I said I wasn’t curious about what the Midgard balanced output does or doesn’t do with the Caldera!
@theveterans Do you have any idea how Midgard balanced output vs Nitsch Pietus Maximus would compare with the Caldera?
Thank you. Even though sound signatures are different, can we say that Piety is technically superior with more detail, resolution and punch?For most headphones:
Midgard on Halo = more transparent to Mojo 2's or any DAC's tonality, wider, spacious, tighter but textured bass
Pietus = warmer, fuller, more refined (trailing edges are resolved better), better bass impact and extension
It's in the DIY under Titan Mesh as an option in the dropdown (Mantle) : https://shop.zmfheadphones.com/collections/diy/products/acoustic-titan-meshAnyone know how to get the mantle mesh for the Calderas? Is it only via email? I couldn't find it on their website, and its been about 2.5 weeks that I've reached out to ZMF but haven't heard from them. Thick pads I know are on their site but I want to get them in a combo if possible.
Loving the Calderas but I do want to reign in those upper-mids a bit more. Thanks.
Gotcha-thank you!It's in the DIY on Titan Mesh as an option in the dropdown (Mantle) : https://shop.zmfheadphones.com/collections/diy/products/acoustic-titan-mesh
I purchased my coffee-stained oak Caldera with the mantle mesh installed. Knew I needed it and figured no sense messing around.Thick pads I know are on their site but I want to get them in a combo if possible.
Your impressions along with a few other mirroring ones definitely have me excited to try out the mesh/pad rolling. I am not particularly sensitive to the upper-midrange/treble upper frequencies with the stock Caldera, but it does come across as a bit harsh and shouty (from my system at least) relative to the more laid-back Elite & Susvara. The intimate staging is nice but I do hope the pads help open up with the stage width just a tad a bit more. The stage depth is great, but I guess I am spoiled from the Elite & Susvara for soundstage width wrapping around your head.I purchased my coffee-stained oak Caldera with the mantle mesh installed. Knew I needed it and figured no sense messing around.
The lambskin thick pads were one of the four pad sets I got with the headphone. I tried them all (the stock pads are really good), but as soon as I put the thicks, that was it--the sound locked in & became pure goldilocks for my treble-averse ears.
(those pads are never coming off...)
IMO the Caldera is a fascinating planar headphone. It has a lot of resolution; with the stock mesh and right choice of earpads, it's easy for the resolution-seeker to push that aspect of the headphone even higher. The Caldera also has a very high level of musicality & musical realism lurking in its drivers; with the Mantle mesh and thick pads, the tonal beauty of music comes through even more clearly. I don't know of many TOTL headphones that are so graceful about going in the particular sonic direction desired by the user.
And oh, by the way, this planar bass is outstanding.
