DimitrisZ
- Apr 6, 2011
I'm with bock3n on this one. Spending money on your transducers is the most important thing, DimitrisZ. They hit the wall of diminishing returns a lot later than anything else in the signal chain so spending money on transducers will give you the most SQ for your money. In most cases it doesn't make sense to go nuts upgrading the rest of your signal chain unless you've already got the best (to your tastes) transducers you can afford. You usually shouldn't bother inching up the diminishing returns of DACs and amps until its cheaper than upgrading your transducers.
Its simple. If you've already got a top tier transducers and have more money to spend then it makes sense to spend that money on a better source and amplification because you can't upgrade your transducers. This is especially true with IEMs since they're so easy to drive. An ipod, LOD, and cmoy plus a top teir custom is going to sound better than a universal which costs half the price but is fed from a world class source and amplifier. That top tier custom may not be living up to its full potential from a humbler source, but its still the best way to spend your money.
That's about as politely as I can put it.
Maveric, I believe that the trend of our times is people to buy a really expensive pair of headphones, run it from cheap sources and just save money to buy a better pair, because they feel that they are satisfied from the sound of their sources and blame for everything else the headphones. I see less and less the trend of buying a pair of headphones and build then a system around it. i think many people here take as de facto running a ES5 from an ipod nano with a portable amp.
