Jmop
- Sep 17, 2014
Which 100 ohm adapter is a good one to get for the 4R? Also, where can I purchase the discussed Phonak ear tips? Thanks.
Which one would you guys recommend for the Fiio x7, westone 4r or u900s?
I'm coming from the 1more triple and looking to upgrade.
My sound preference is neutral to a tad bit bright without losing the bass of course.
Kinda like it03 with a much smaller Shell.
Maybe a silver cable might work. Is the Sony on the warm side of things? I've never heard the w40 but have owned the w4 a couple times and they were on the warm lush side? But I'm thinking trying a silver cable.So I unfortunately I don't have the time to go through 370 pages lol. And I couldn't find a dedicated W40 Thread, so I figured I'd ask my question and hope for the best. I have a pair of W40's and while I really love their laid back and natural sound (which is exactly what I was looking for), they are lacking in some detail, soundstage and separation for me. I have a a Sony PHA-3 AMP/DAC, which I think is a stellar device, and. couple sets of cans that I use with it with balanced silver cables. My question I guess is do you think it's worth buying a balanced silver cable for the W40's to try and achieve the areas that I believe are somewhat lacking, or just investing in a higher end set of IEM's? The cable I would be buying would be from Moon Audio, and after the investment in the cable, the set up would be totaling around $650. So like I said, I guess I'm looking to see what your opinions are from anyone who has a balanced set up with these and/or higher end IEM's that they think are worth the price. Thanks for all your help!!!
Just my 2 cents. BTW, I'm not a contributor or anyone special...just a guy that loves enjoying music. From owning and trading quite a few headphones, amps, dacs, and daps, I have learned that, IMHO, it's best to find the headphones with the sound you enjoy rather than investing a lot in accessories. Also consider synergy with your gear. One amp/dac may not sound as good to you with a certain set of headphones.
For example, I traded and tried a bunch of iems until I hit on the Sony EX800ST's. They're my endgame as I get great separation, detail, soundstage which sounds like a live speaker. I get clarity and great sound from an iBasso DX90 and a Fiio E12A amp. When I want, I can cover the vents on the Sonys and they turn into bass monsters. The point is, they're the sound I like best. I recently purchased a cable for the Sonys because the stock one is terrible and I'll be keeping them but it's more about functionality than sound. The sound is still the Sony.
Dear fellow headfi'ers,
I have a burning question I need answered. After receiving daily amusement for the last 5 years my W4R finally decided to end our relationship :'( . After about an half hour of playing the right monitor loses volume, which leaves me with a unbalanced pair of IEMs. My left monitor seems fine after continued hours of playtime, I only experience problems with the right one. I also bought a new set of cables to try to fix this problem, but without success.
After that I contacted the official Westone dealership in my country where I bought my pair (Variphone). They told me that the life expectancy for this line of IEMs is 3 years and they didn't have any spare parts because of the replacement of the older line of models. Long story short: I'm left with a broken pair of IEMs. I'm planning on contacting Westone itself and ask if they can help me out, but I'm not feeling very hopeful.
My question: are there any third-party companies or individuals who can repair my IEMs? Or maybe fixes I can preform myself? I don't really have the budget to upgrade or replace them at the moment.
Thanks in advance !!
