james444
- Aug 25, 2004
The IE8 is surely capable of producing nice vibrating low bass, the problem is the mid/upper bass hump at 80-100Hz which is way too prominent and simply drowns out everything else. Try a low frequency sweep and you will see it can vibrate quite nicely and go down below 20Hz. Same with the mids, they are not that recessed, a bit laid back ok, but I suppose the main reason you find them recessed is this massive mid/upper bass drowning out part of the midrange.
Now the FX500 doesn't have this mid/upper bass hump and therefore more room for the low bass to shine. On the other hand, with no mids-invading upper bass to blame, the mids on the FX500 are *really* somewhat recessed. So, as much as I like both of these phones I don't believe jumping from the IE8 to the FX500 in search of better mids will make you happy.
I'd recommend trying to tame the IE8's bass before dismissing them. IME there are two possibilties: pair them with a bright amp/source or a source with a high quality equalizer. I'm doing the former with the Nuforce Icon mobile and the latter with a rockboxed Fuze. Both give great results and transform the IE8 into entirely different, more likeable phones IMO. I own quite a few IEMs and I do not think any them is an upgrade to the IE8 if you take the bass hump out of the equation.
I do realize you have no EQ on your Zune at the moment, but you plan upgrading to Sony X or Zune HD in the future which both have EQ, the Sony's supposedly a very good one. My advice would be to upgrade the source first before jumping from the IE8 to a different IEM.
Originally Posted by ignorant /img/forum/go_quote.gif I just bought the Sennheiser IE8s a month ago and now I'm looking at these guys for an upgrade : ( I feel the statements about the bass to be true; they just don't produce that nice vibrating bass that I've been looking for. They do have a lot of mid and upper bass but I want to feel the bass. There isn't enough treble quality for me either (I came from the Phonak Audeo PFEs) and I'm hoping that the mids aren't as recessed with the FX-500s as they are with the IE8s. I still feel that the IE8s are a great set of IEMs because they produce that nice full sound, instrument separation, etc(you've heard it all before) but there's still some things left to be desired |
