ljnew
- Dec 24, 2015
Ok thanks.He's explained it several times in this thread. Has to do with licensing agreements and encryption. You can only play downloaded content through the Tidal app.
I wonder if anyone can help me, I'm getting an 'error decoding' toast message when I try to stream some MQA Tidal tracks to my Meridian Explorer 2 bit -perfect. I'm using a Google Pixel XL via the official USB-C to A adapter to the official Meridian OTG cable to the DAC.
The setup works perfectly when playing 16/44.1 streams from Tidal and also MQA tracks with 44.1Khz sample rate such as Ed Sheeran's 'Divide' album play perfectly with the blue light. However if I try to stream MQA versions of 'Hotel California' which has a much higher sample rate and 'Californication' by Red Hot Chili Peppers which has a sample rate of 48Khz then I get the error toast. If I don't use bit-perfect then it works but it's not ideal.
Has anyone else experienced this?
@Davy Wentzler THANK you for adding a way to identify MQA!
But "HiRes" (with a hyphen, but still) is a marketing term for anything higher than 16/44.1.
Is there a legal reason you can't use "MQA" instead?
No, some streams are 48k/24-bit, even if you don't use a MQA decoder.
Those are undecoded MQA? Or other streams?
Undecoded MQA
Finally, that nasty problem has been solved in yesterday's update! I was waiting for almost half a year but thank you anywayAfter starting the app, the first song that was already in the queue did not play according to the DSD and bit-perfect options set. Solved.
Am I right in assuming that, in regards to Android resampling to 48 kHz or not, UAPP will not help anything with a Note 4 (Snapdragon) when using its headphone output?
I don't have a USB DAC and was thinking of getting the LG V30 once they become available. Been wondering if there's any benefit to start using UAPP right now with my Note 4, as far as Android messing up with the audio is concerned.
