REXNFX
- Feb 18, 2014
yes, the app works, weird indeed...
OK now mine not working! last UAPP update has disabled Tidal
It was $10 down the hole for me. It won't play tracks in track order (defaults to alphabetic) when playing from DLNA server (MybookLive), even when the server is properly configged. Every other (free) player picks up the config file properly. UAPP was really disappointing and misleading because of this. They should offer money back, as it doesn't properly support dlna
http://www.head-fi.org/t/747055/android-dlna-twonky-and-usb-audio-player-integration/15
Plays tracks in track order from Foobar2000, JRiver and Plex just fine for me, no problems.
Why offer a money back? They offer a risk free trial version...
They were advertising DLNA support, I expected that it was going to work
Sure, they also recommend trying the free version first to check that it meets your approval prior to dropping your cash.
If you email them they will probably offer a refund in any case, most devs are fairly good like that (also report your difficulties to them, they have been awesome at continual support with updates and may well fix that for you).
