- Oct 22, 2014
S8+ Airplane mode w/UAPP Bitperfect FLAC's --> Hugo2 --> A18 w/M20 is incredible.
would there be access to spotify via usb audio as spotify even if its mp3 but its the most used music streaming app
OK. So Media volume is actually controlling the same volume as UAPP's hw volume (i.e. Dragonfly's internal volume), but just within a more limited adjustment range? (Which would explain why it doesn't matter for playback fidelity where Media volume is set at.)
I finally had some time to check this out. It is controlling hardware volume, but since the controls are not coupled, the range of the media slider does not match the range in UAPP. Basically, it only makes sense to use the volume up/down buttons. The problem is that when UAPP's screen is in front, we can block the volume dialog from popping up and blocking the change of the media volume. This does however not work, when UAPP is not in front, which is why you see the media volume changing.
As Onkyo Granbeat can decode MQAs, I wonder if there is a way to play back Tidal Masters MQA on the Onkyo Granbeat with the MQA settings for LG V30?
Any experience?
Will offline listening be supported for Google Music via USB audio?
You mean only 2 songs can be listened to offline? Weird. I'm on the search for a music service that I can listen to offline via USB audio.Kind of. The Google Music URL is only active for one minute, so what happens is that the entire song (and the next) is downloaded to an offline cache. The song gets an indication (offline) behind it. You can play these songs offline. However, there is no facility (yet) to download an entire album in advance.
Love the update though.
