USB Audio Player PRO (UAPP): 24- and 32-bit playback, ubiquitous USB audio support for Android
Feb 2, 2020 at 10:31 PM Post #3,422 of 6,159
Sorry if this has been asked previously - Can UAPP do the same as Poweramp & resume tracks where they last stopped? Including, if the app is completely closed.
Feb 3, 2020 at 5:50 AM Post #3,423 of 6,159
Yes.
Feb 3, 2020 at 6:04 PM Post #3,424 of 6,159
Is there a setting I need to check in the app, as mine doesn't seem to be doing this. I'm using the paid version on an LGV30.
Feb 4, 2020 at 1:12 AM Post #3,427 of 6,159
You might want to buy the MQA addon
MQA addon for me has been a disappointment, many times a studio MQA album fails to buffer, even it does it isnt as smooth of a buffer speed, my network is on full signal 4G+ with speedtest download of 72mbps typical so its not because of net speed
and if it fails to buffer once, it will say usb setup fail and the whole thing goes weirdo
Feb 4, 2020 at 6:54 AM Post #3,428 of 6,159
If I buy this for the LG G7, are their any in-app purchases I should make as well? My primary use for the app will be for using in conjunction with Tidal.
MQA add-on is for software decoding. LG phones with ESS Quad DAC have hardware decoding and rendering and don't need the add-on. You have to enable the MQA HiRes driver flag in UAPP settings to use the hardware MQA feature.
Feb 4, 2020 at 2:47 PM Post #3,429 of 6,159
I just noticed this UAPP item in my notifications that says "UAPP renderer". Never seen it before.
