Shini44
- Sep 22, 2012
oh this post is alive? all the people moved to the mentor hehe, still the miracle can stand on its own for sure <3
Hi folks,
The countdown clock is ticking and my new custom Miracles should be in my sweaty palms in the next few hours.Waiting, waiting.
I have 2 questions if you please.
How long is the normal 'Breakin' period?
And....
I was wondering what you drive your Miracles with at the moment and what you might have tested them with.
I currently have a Clip+ with a Fiio 11K amp. I use flac files exclusively. I have some high Rez 24/96 files but the clip won't play them. No big deal really at this stage.
Once the Miracles have broken in and I was pondering a source upgade, what would suggest I look at.
I see you have Cowan's listed as a good source. I guess the ibasso dx50 or dx90 would be on the list. Anything else?
Thanks for any advice you might give.
Regards Cazzesman
I honestly really liked it with the Fiio X1, believe it or not. Much more than with my Cowon J3. People say they scale up very well with better sources, and though it's a bit dated, the ibasso DX100 is supposed to really make them sing.
as far as i recall Cowon J3 isn't the best option for the Mircale and in fact it does sound wrong with it,
i remember discusing this like two years ago on this thread with the top head-fiers from this thread, back in the days when i was looking for a DAP for the Miracle.
you will easily notice that when you try the Miracle with DX90 or Fiio X5 but going from Fiio X1 to the J3 i guess you will see the J3 as a better option.
gratz man!! also make sure you give them at least 10-15 hours before you judge them , your brain need to get used to the sound, the miracle is balanced and fun,
what are you using it with?
I currently have a Clip+ (Rockboxed) with a Fiio 11K amp. I use flac files exclusively.
Regards Cazzesman
Thanks the Amp suggestion.
What about replacement of the stock cable. I have read plenty about the ....
Silver Dragon V1 IEM Headphone Cable
Or any other cables worth researching?
Any thoughts on a change down the track??
Regards Cazzesman
etc
