lin0003
- Jan 4, 2013
I don't think anyone has both.
The Roxanne has a pretty long wait because of build time and quality control of the carbon fiber hasn't been up to snuff - take a peek over on the JH Roxanne thread. I think the Mentor is a safer bet. Consider the Noble Audio 10-driver CIEM, too.
I actually want to upgrade my miracle since the socket is not tight anymore and I do not want to pay another 150 for re-shell it.
Since both JH audio and UM are offering 10+ driver solutions, I was wondering which one should I go?
The Carbon fiber Roxanne, or the new Mentor?
I normally use it to listen to less serious music like pop, hip-hop, rock and some vocals. It is my portable gear so I do not demand crazy high resolution, but do need good dynamics and tight bass controls. The efficiency and sensitivity will not be a issue since I have a DX100 which I hope can power up any IEM fine.
Any suggestions?
The Noble Audio only have 5 Drive each, hence 10 driver total. But the Roxanne has 12 each total of 24 driver and Mentor has 10 each and total of 20 drivers (which 2 of them are the very expensive one for mid high).
I know more driver does not mean better sound, but based on the cost of the Noble Audio is almost the same as the other two, I think UM and JH are better valued. (The development will also be more for more drivers since the crossover and internal layout of the drivers are much much harder to design).
Noble K10 have 10 drivers per side, hence 20
Trying to decide on a colour scheme is going to be the death of me.
I cant choose.
I have thought solid black face with red wine shells, Solid white with Purple shells and the below two... (would be going both same colour, just put 2 different ones to save time.
Just the pictures on the designer dont seem realistic, the colours seem over exposed.
Thoughts?
