lin0003
- Jan 4, 2013
Got my Miracles today! It sounds great, but not such a big upgrade to the B2s than I thought that they would be. I will hopefully compare them to other high end IEMs soon.
I'm going to send mine for refit ..
Should I get impressions for both ears again, or just the right one?
You should try both. Personally, I think that people overrate custom IEMs' comfort levels. I actually feel like they hurt quite a bit when inserting and taking out. Sound is detailed and with an aftermarket cable the sound really does get better.
This one happens on my right ear. The cable is very tight, I could not unplug it. I have the 1plus2's silver/gold cable
It happens to me on both ears... How is it with the silver/gold cable? I'm not sure if I should send it back or not because I don't want to wait so long again.
I completely agree with the above. While my IEMs are comfortable I don't find them to be as comfortable to a good fitting universal IEM. My ears with a custom always feel filled.... Just feels weird to be honest. Although I've heard some really good things about the Spiral Ear SE5 and the Fit Ear 335. So I'll reserve total judgement until I try those . But across the board I think the comfort is way overrated...
I can't put the silver/gold because the cable on the Miracle is very very tight
On my right, I feel the stem short, the shell is not as tight like on the left.
On my left, it just disappears ...
I sort of have the same problem as you do. My left ear is great, but my right ear feels a bit weird and breaks seal more easily than the left. And for the cable, i found it hard to remove as well by just pulling it, but if you slowly and carefully (you wouldn't want the pins breaking and getting stuck) wriggle the connector while pulling it outward, it should come out after about 20 seconds.
I can't really say mine disappear. I pretty much know they are always in my ears if that is what you mean. They are comfortable though where I can wear them for hours without issues. But not so comfortable that I forget they are in my ears.
But on the plus side the fit is generally quite good on mine. On both sides. I don't have issues with losing seal. I can eat and not lose seal. The seal is so good when I lye down I hear my own heartbeat.... That part is annoying if I want to listen to music at a very low volume lol... On initially incerting them the isolation is so good I hear the silence noise. :evil: Very handy for ignoring people .
Is that the reason why you sent them back again before?
That's how they isolate for me too.. It's really hard to explain what I am feeling on the right side.. Even when I move side to side, move my mouth or open them widely, i don't lose the seal.. I can't understand what's wrong with my right..
funny to read this.
I don't have the miracles, but have a shure 530x8 reshelled by UM, and i have the exact same thing going on. I was afraid my right ear was weaker then the left, but no.
My only explanation is that we had no luck, and the density of the pieces varies form one side to another. Because, when i thought about it, with the music on, the fit was/is perfect, but i can hear more of the outside world on the right side then on the left.
Thanks for the explanation. This only confirms that I'm not the only one. Maybe I don't need to ask for a refit.
This is also exactly what I hear. My left one is 100% sealed and right one is like 90-95% compared to the left but they fit and not lose seal at the same time..
