dan_can
- Jun 14, 2005
SoundFreaq, have you ever heard Ed9? If so, I really want to know your thoughts about it compared to SP.
OK, I've spent some more time with the two of these headphones, the SigPro and SigDJ. I also brought in another set of ears that is good with picking out detail in music, and I totally trust.
To us, we agree the SP is just more refined and cleaner. Treble is smoother while still being super detailed. And the mids are more natural and organic. The bass is tighter on the SP. I actually think the SP has more sub-bass, but it may be that this is only the case because the sub-bass on the SP shines through more because the SDJ has more mid-bass which overshadows the sub-bass. When I am listening to SDJ, I very much miss the refinement of the SP. And when I am listening to the SP, I crave that touch more bass. Seeing as how I own the MG6Pro for monstrous bass, I don't see myself keeping the SDJ right now. They both do things very well, but for me, I miss the refinement and control of the SP over the more robust bass of the SDJ, I am surprised to say. We both agree the SP is a classier and more fun sound. There are just less faults in the sound.
This evaluation is far from over. I am just letting you know how it goes as it goes. Hope it helps.
Guys, things continue to change with burn in. I need to do a more in-depth comparison using EQ measurements to be able to give a more accurate representation of the bass boost over the SP. I need to let the SDJ burn some more.
Everything aside, the bass of the SDJ is miles ahead of the Pro 900. Everything about the sound signature is more refined. Does it have AS MUCH bass impact? I can't tell you definitively, since it's been over 4 months since I got rid of my second pair. But this is a fun pair of headphones, and the bass is more plentiful than the SP, and maintains an impressive control.
More to come.
Man, you're making me feel like taking the SigPro & SigDJ out of it's bubblewrap to have a listen to.
Using a basic equalizer, and with my specific pair of headphones, this is how I have to EQ the Sig Pro to sound like the SigDJ. And once I do achieve essentially the same sonic signature, the SP sounds fuller and more alive. Essentially I can EQ my Sig Pro to become a better Sig DJ, in my opinion.
Bands, in Hertz: 32, 64, 128, 256, 512, 1K, 4K, 8K, 16K
The 64Hz band is about a +3.5, and 2Khz at -1.5. So if using the SP mids as a base line, the SDJ would have about a 5db boost with a peak at 64Hz. I initially thought about 7db, but noticed the SDJ becoming a tad more evened out as burn went along. Hope this helps.
Disclaimer: I am no expert. This is to MY ears, with my sets of headphones, which could vary from yours given Ultrasone's QC reputation. This was done using extensive A/B testing using various electronic dance tracks.
Without that rise in the high end, the SDJ would be entirely too dark. The bass emphasis over the SP is more substantial than the treble emphasis. And if I keep this EQ setting and listen with the SDJ with it, watch out brother. That's rich stuff right there. I will experiment more with it later on.
Yeah these things can take some serious power and deliver. I EQ'd up a solid 4.5db from 50-150 or so and then fed it my LF, nearly full tilt. It was run out of the low impedance output, but it surely was more than half of the total power of the amp, which is rated at 4 watts. At the low gain output, conservatively, I was pushing a full 2 watts of bass-gained, bass centric music through these guys. They felt like the were pushing off my head. I couldn't handle it for more than a few seconds. The Sig Pros definitely can't push raw power like that. Coupled with the refinement against the other bass cans I've heard, I'd say these are easily the most capable and refined bass can I've put on my head. And the thing is, they are not deal breakers for other genres like I thought the Pro 900 was.
