Kernmac
Whoa they updated the accessories included? Kernmac, where did you buy your 2nd pair?
Can't stop tinkering with these, I'm afraid the screws are starting to strip.
Purchased from Ebay powerseller. Cheapest and most reliable on Ebay. Simply look for Pro 900 and it will come up. Plenty of Headfiers have purchased from this seller, and not just Pro900s. As to the screws. The phillip head screws are soft and it doesn't take much to strip the head, as to stripping the thread, you must be careful as you are screwing into plastic. Purchase new screws (2 mm Diameter and 6-8mm length) ensure that they have decent heads on them and screw them in nice and straight. I am very happy with my latest Kees Mod job, not too much cotton or you kill off that magical bass; depth, volume and slam. Just the right amount of cotton/felt dampening and the Pro 900 is as good as it gets.
