So in response to your request for a cable, you have very limited options since you want angled connectors. The way TRN designs their angled plugs is pretty unique to TRN, so your choices are pretty much limited to TRN upgrade cables.
Plus, since most of the TRN upgrade cables use straight connectors, your only choice would specifically be the 6-core TRN upgrade cable:
Be aware that it has 2 ‘fake’ wires that aren’t actually connected to anything internally. So it is, in reality, a 4-core cable (just like the stock cable). It has exactly the same resistance as the stock black 4 wire cable. So from a resistance aspect, consider the 6-core upgrade cable the ‘same’ as the stock black cable.
On the positive side, it is thicker and less tangly (and looks nicer). So as long as you’re OK with only 4 wires being internally connected, then it will work for what you want.
To find it on Aliexpress, search for “TRN 6 core cable”.
[/QUOTE
Are you sure ? I think its a true 6 core cable
