Mimouille
The sound of your credit card slowly agonizingThe sound of the uber is truly intoxicating.
I wrote a review of the Uber cable a few months back :-Can u describe the improvement of uber cable in more detail please? If possible ?
http://www.head-fi.org/products/tralucent-audio-uber-cable/reviews/8933
I had the same problem. This pipe tape helped (black color). Just put a little piece on every side of the shell where connector go and your problem will be solved.
I agree with mostly everything Sean put in his review. The biggest difference I've heard thus far is the treble energy. If you are like me, that can't stand strident or harsh treble than the uber cable just might do it for you. The difference between the gold/silver (version 1) vs. uber cable is actually more significant than I thought it would be. Typically, I don't hear huge or even moderate differences or changes in the sound with other swapping of cables, but with the 1plus2 the cable really does make a difference. The presentation is quite a bit more refined. It just takes what the 1plus2 does good and makes it great. There are only two things that should keep people away from the uber... that is price and durability/fragility.
Thank you very much! Don't they call that PTFE tape or something? Luckily I am on a ship, so I shall just go and see the electrician or Chief Engineer! THANKS!
