Legendac87
So you used like a handphone charger as the linear power supply?Not a modification as such, but a linear power supply made a positive improvement to sound quality for my D50.
Ahh gotcha. Thanks!No, I used an actual linear power supply as a linear power supply! Previously I has just used a phone USB 5V charger and a powered USB hub port. At one point I used an iFi iPower 5V power supply. However, a proper linear power supply helped to deliver the best sound quality.
Change other USB, and input the back USB of your PC.
https://twitter.com/shenzhenaudio
Stay updated on ShenzhenAudio at their sponsor profile on Head-Fi.
I have tried all of that and none of them workedChange other USB, and input the back USB of your PC.
ya that is the first thing I have tried. I also tried different usb ports and also tried on my sister's laptop and still no luck.I haven't read back through all of your posts discussing this issue, so apologies if you've already tried this. Have your tried different USB cables?
Uhm I dont know, but I am glad I can still use it using spdif while waiting for another DAC that I have ordered. I hope this is not a quality control problem and that there are very few people who experienced this.Ah, okay. It's toast then. Perhaps a bad solder joint or a chip blown?
If so, pls ask for an after-service from the seller.I have tried all of that and none of them worked
Unfortunately mine is already out of warranty, and I ordered smsl m400 so I will just use it with the optical connection for the meantime.If so, pls ask for an after-service from the seller.
Unfortunately notDo you have the opportunity to use the digital coaxial output? If so, I would use that rather than optical.
Have you tried installing topping asio driver?I cannot get my D50s to play any DSD files over USB from my Windows 10 laptop via Foobar2000. I downloaded and installed the latest ASIO drivers, following the installation and setup guide carefully. All of my hi-res files show their resolution on the D50s display, and they sound fine, but nothing shows up on the D50s display when I play a DSD file, and there is no sound. I had no difficulty playing DSD files with my Marantz DAC, so I'm assuming it's a matter of settings??
Here's where I downloaded the v4.86 drivers: https://www.tpdz.net/download
